Creating an Application
- Log in to the APM console.
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- Click
on the right of Application Metric to create an application. Figure 1 Creating an application
- In the displayed dialog box, set application parameters.
Table 1 Parameters for creating an application Parameter
Application Name
Name of an application, which cannot be empty.
Enter 1 to 128 characters and start with a letter. Only digits, letters, underscores (_), and hyphens (-) are allowed.
Display Name
Application alias. The alias takes precedence over the application name to display.
Enter 1 to 128 characters. Only digits, letters, underscores (_), hyphens (-), brackets, and periods (.) are allowed.
Enterprise Project
Select an enterprise project from the drop-down list. This parameter is displayed only when you use the enterprise edition.
Description of the application. Enter up to 1,000 characters.
- Click Confirm.
After an application is created, connect it to APM for monitoring. For details, see Getting Started.
