Updated on 2025-11-18 GMT+08:00
Alarm Policies
Only applications whose access mode is SkyWalking support alarm policy settings for a single component.
Creating an APM Alarm Policy
  1. Log in to the APM console.
  2. Click on the left and choose Application > Application Performance Management.
  3. In the navigation pane, choose Link Trace > Metrics.
  4. In the tree on the left, click next to the target environment. The Component Settings tab page is displayed by default. Switch to the Alarm Policies tab page.
  5. Click Add Alarm Policy.
    1. Basic information
      Table 1 Basic information about an alarm policy
      Policy Name
      Custom name, which cannot be left blank.
      Only letters, digits, underscores (_), and hyphens (-) are allowed. Enter up to 512 characters.
      Alarm Severity
      Severity of an alarm. Options: COMMON and CRITICAL.
      Monitored Object
      Name of the object to be monitored. The default value is the name of the current environment and cannot be changed.
      Alarm Policy Type
      Options: Single-node and Aggregate. Single-node indicates single-instance metric alarms, and Aggregate indicates aggregated metric alarms of all instances under a component.
      Monitoring Type
      Select a monitoring type. The information about the selected type is displayed on the right.
      Metric Set
      Select a target metric set. The information about the selected metric set is displayed on the right.
    2. Alarm rule
      Figure 1 Alarm rule
      Table 2 Parameters for setting an alarm rule
      Dimension
      (Optional) A fine-grained category of metrics.
      Metric
      Metric for which you want to define one or more alarm rules.
      Metric: a metric in the metric set. For example, if Monitoring Item is set to Url and Metric Set is set to total, you can select the errorCount metric.
      Operator: operation to be performed.
      Threshold: threshold of the metric.
      Alarm Condition
      Condition for triggering an alarm.
      A: the number of collection periods. Range: 1–10.
      B: the number of times the alarm is triggered. Range: 1–10. This value cannot be greater than that of A.
      C: period (in minutes) during which identical alarms will not be sent. This period cannot be shorter than 10 minutes.
      Recovery Policy
      Condition for clearing an alarm.
      Notification upon Recovery
      Whether to notify recipients of alarm clearance.
      Strict Mode
      Checks all returned values against alarm rules to detect exceptions.
      For example, if a host has multiple CPU cores, there are multiple single-core CPU usages (such as cpu_no=0 and usage=98; cpu_no=1 and usage=99).
    3. Alarm Notification
    Table 3 Alarm notification parameters
    Notification Content
    Alarm details, which contain up to 500 characters.
    • If Strict Mode is enabled, the alarm notification content supports both Variable and Loop. If Strict Mode is disabled, only Variable is supported.
    • Alarm notification content. You can customize the content or select required metrics.
    • Select the metrics to be collected. On the right of the page, click next to a metric. The metric will then be referenced to the notification content box.
    Notification Object
    • Select a notification object from the drop-down list.
    • Alarms will then be sent to the selected notification object. Unselected notification objects will not receive the alarm notifications.
    • Click to refresh notification objects.
  6. Click OK.
More Operations
After the alarm template is created, perform the operations listed in Table 4 if needed.
Table 4 Related operations
Operation
Editing an alarm policy
Click in the Operation column.
Deleting an alarm policy
Enabling or disabling an alarm policy
Click or in the Operation column to disable or enable an alarm policy, respectively.
