Topology
The topology displays the call relationships between services within a period. The statistics can be collected from the caller or the callee. You can also view the trend. On the topology, you can view the call relationships between services and check whether the calls between services are normal to quickly locate faults. The application relationships, call data (service and instance metrics), and health status are clearly displayed.
Viewing the Topology
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- In the tree on the left, click
next to the target environment. - Switch to the Topology tab page. The call trend of the selected instance is displayed.
Figure 1 Viewing the topology
- Click
next to Display only calls between components.
Figure 2 Displaying only calls between components
When the button turns blue, only the calls between components are displayed.
Figure 3 Calls between components
- Click Show All to display all call relationships of the selected instance in a specified time range.
Figure 4 Showing all
- Click Reset Layout to restore to the initial topology.
- Select the refresh mode and time. Default: Manual Refresh. In addition, Automatic refresh in 1 minute, Automatic refresh in 5 minutes, and Automatic refresh in 15 minutes are supported.
Figure 5 Selecting a refresh mode
- Select a time range. Default: Last 20 minutes.
Options: Last 20 minutes, Last hour, Last 3 hours, Last 6 hours, Last day, Today, Yesterday, Last week, Last month, or Custom.
Figure 6 Selecting a time dimension
- Click
to refresh the topology. - Click
to download the current topology to the default path.
- Click
