- What's New
Service Overview(2.0)
- What Is APM
- Functions
- Application Scenarios
- Basic Concepts
- Edition Differences
- Permissions Management
Metric Overview
- Exception
- Basic Monitoring
- C3P0 Connection Pool Monitoring
- Cassandra Monitoring
- ClickHouse Database
- DBCP Connection Pool Monitoring
- Druid Connection Pool Monitoring
- EsRestClient Monitoring
- GaussDB Database
- HBase Monitoring
- Hikari Connection Pool Monitoring
- Jetcd Monitoring
- MongoDB Monitoring
- MySQL Database
- ObsClient Monitoring
- Oracle Database
- PostgreSQL Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Communication Protocol
- Privacy and Sensitive Information Protection Statement
- Data Collection
- Usage Restrictions
- Billing
- JavaAgent Updates
- Billing(2.0)
- Getting Started(2.0)
User Guide(2.0)
- Before You Start
- Application List
- CMDB Management
Application Metric Monitoring
- Overview
- Application Monitoring Details
Application Monitoring Configuration
- Configuration Details
- Configuring the MySQL Monitoring Item
- Configuring the HttpClient Monitoring Item
- Configuring the URL Monitoring Item
- Configuring the JavaMethod Monitoring Item
- Configuring the Druid Monitoring Item
- Configuring the ApacheHttpAsyncClient Monitoring Item
- Configuring the Redis Monitoring Item
- Configuring the Jedis Monitoring Item
- Configuring the HBase Monitoring Item
- Configuring the ApacheHttpClient Monitoring Item
- Configuring the Tomcat Monitoring Item
- Configuring the EsRestClient Monitoring Item
- Configuring the WebSocket Monitoring Item
- Configuring the KafkaProducer Monitoring Item
- Configuring the Hikari Monitoring Item
- Configuring the Exception Monitoring Item
- Configuring the Thread Monitoring Item
- Configuring the GC Monitoring Item
- Configuring the JVMInfo Monitoring Item
- Configuring the JVMMonitor Monitoring Item
- Configuring ProbeInfo Monitoring Item
- Monitoring Item Views
- Instance
- Collection Status
- Component Settings
- Tracing
- Application Topology
- URL Tracing
- Resource Tag Management
- Managing Tags
- Alarm Management
- AgentAgent Management
- Configuration Management
- System Management
- Change History
API Reference(2.0)
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
APM
- Querying the application list.
- Querying the Master Address
- Obtaining the AK/SK
- Searching for Components, Environments, and Agents in a Region
- Saving a Monitoring Item
- Querying the Monitoring Item List
- Querying All Agents of an Application
- Enabling or Disabling Collection for an Instance
- Deleting an Agent
- REGION
- CMDB
VIEW
- Querying Monitoring Item Configurations
- Querying the Trace Topology
- Querying Event Details
- Querying Span Data
- Obtaining All Data of a Trace
- Obtaining the Trend Graph
- Obtaining Summary Table Data
- Obtaining the Raw Data Table
- Obtaining Raw Data Details
- Obtaining the Instance Information
- Obtaining the Monitoring Item Information
- Obtaining the Details About a Monitoring Item
- AKSK
- ALARM
- TOPOLOGY
- TRANSACTION
- TRACING
APM
- Appendix
- Change History
- Best Practices(2.0)
- FAQs(2.0)
- Service Overview(1.0)
- Getting Started(1.0)
- Best Practices(1.0)
- User Guide
- API Reference
- SDK Reference
- General FAQs
- Consultation FAQs
Usage FAQs
- How Do I Obtain the AK/SK and Project ID?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Can I Do If No Data Is Found or the Data Is Abnormal?
- How Do I Connect APM to Non-Web Programs?
- How Are Tracing Time Lines Drawn?
- How Does APM Collect Probe Data?
- How Does APM Collect Mesh Data?
- How Do I Calculate the Number of Used Instances?
- How Do I Connect the JBoss Server in Standalone Mode to APM?
- What Can I Do If I Cannot Search for Logs Based on Trace IDs?
- How Do I Deploy APM Probes in CCE Containers?
- What Can I Do If the SSH Tunnel Process Is Abnormal?
- How Can I Do If No Topology or Data Is Displayed After the ICAgent and Java Probes Are Installed?
- Why Are Tomcat Thread Metrics Not Displayed on the JVM Monitoring Page?
- Why Is the Allocated Memory Greater Than the Preset Maximum Memory on the JVM Monitoring Page?
- How Do I Determine Whether an ICAgent Has Been Bound in CCE?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (2.0) (Kuala Lumpur Region)
Service Overview
- What Is APM
- Functions
- Basic Concepts
Metric Overview
- Metric Overview
- Exception
- Basic Monitoring
- GaussDB Database
- HBase Monitoring
- Jetcd Monitoring
- MySQL Database
- Oracle Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Data Collection
- Getting Started
User Guide
- Before You Start
- Application List
- CMDB Management
- Overview
- Tracing
- URL Tracing
- Managing Tags
- Alarm Management
- Agent Management
- System Management
- FAQs
- Change History
Service Overview
Show all
Web Container
This function monitors web containers, including Tomcat. This section focuses on Tomcat monitoring.
Going to the Web Container Page
- Click
on the left and choose Application > Application Performance Management.
- In the navigation pane, choose Application Monitoring > Metrics.
- In the tree on the left, click
next to the target environment.
- Click the Web Container tab. By default, the Tomcat monitoring information of all instances is displayed. For details about the metrics, see Table 1.
Figure 1 Going to the web container page
Table 1 Tomcat monitoring parameters Metric Set
Metric
Tomcat port monitoring
name
Port name.
Current Threads
Number of current threads on the port.
Busy Threads
Number of busy threads on the port at the time of collection.
Peak Busy Threads
Maximum number of busy threads on the port in a collection period.
Max Threads
Maximum number of threads on the port.
Max Connections
Maximum number of connections on the port.
Current Connections
Number of current connections of the port at the time of collection.
Peak Connections
Maximum number of connections on the port in a collection period.
Version
Version
Tomcat version.
- Click a number in blue (such as those in the Current Threads, Busy Threads, or Peak Busy Threads column) to view the trend graph of the target web container in the specified period.
- Click a version in the Version column to view details.
- On the displayed Web Container tab page, select a target instance and monitoring item to view the monitoring data in different metric sets.
Figure 2 Selecting an instance and monitoring item
- Select a time range. Default: Last 20 minutes.
Options: Last 20 minutes, Last hour, Last 3 hours, Last 6 hours, Last day, Today, Yesterday, Last week, Last month, or Custom.
Figure 3 Selecting a time range - Click
in the upper right corner of the list and select the metric data you want to view.
- Click
in the upper right corner of the list to export information. A maximum of 100 records can be exported.
