Help Center/ Application Performance Management/ User Guide(2.0)/ Application Metric Monitoring/ Application Monitoring Configuration/ Configuring the Thread Monitoring Item
Updated on 2024-12-25 GMT+08:00
On the Modify Thread Monitoring Configuration page, set the following parameters:
- Collection Interval: The default value is 60s and cannot be changed.
- maxThreadDepth: The default value is 10 and the maximum number is 50. If you select Use default value, the value of the inherited tag is preferentially used.
Parent topic: Application Monitoring Configuration
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
