- What's New
Service Overview(2.0)
- What Is APM
- Functions
- Application Scenarios
- Basic Concepts
- Edition Differences
- Permissions Management
Metric Overview
- Exception
- Basic Monitoring
- C3P0 Connection Pool Monitoring
- Cassandra Monitoring
- ClickHouse Database
- DBCP Connection Pool Monitoring
- Druid Connection Pool Monitoring
- EsRestClient Monitoring
- GaussDB Database
- HBase Monitoring
- Hikari Connection Pool Monitoring
- Jetcd Monitoring
- MongoDB Monitoring
- MySQL Database
- ObsClient Monitoring
- Oracle Database
- PostgreSQL Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Communication Protocol
- Privacy and Sensitive Information Protection Statement
- Data Collection
- Usage Restrictions
- Billing
- JavaAgent Updates
- Billing(2.0)
- Getting Started(2.0)
User Guide(2.0)
- Before You Start
- Application List
- CMDB Management
Application Metric Monitoring
- Overview
- Application Monitoring Details
Application Monitoring Configuration
- Configuration Details
- Configuring the MySQL Monitoring Item
- Configuring the HttpClient Monitoring Item
- Configuring the URL Monitoring Item
- Configuring the JavaMethod Monitoring Item
- Configuring the Druid Monitoring Item
- Configuring the ApacheHttpAsyncClient Monitoring Item
- Configuring the Redis Monitoring Item
- Configuring the Jedis Monitoring Item
- Configuring the HBase Monitoring Item
- Configuring the ApacheHttpClient Monitoring Item
- Configuring the Tomcat Monitoring Item
- Configuring the EsRestClient Monitoring Item
- Configuring the WebSocket Monitoring Item
- Configuring the KafkaProducer Monitoring Item
- Configuring the Hikari Monitoring Item
- Configuring the Exception Monitoring Item
- Configuring the Thread Monitoring Item
- Configuring the GC Monitoring Item
- Configuring the JVMInfo Monitoring Item
- Configuring the JVMMonitor Monitoring Item
- Configuring ProbeInfo Monitoring Item
- Monitoring Item Views
- Instance
- Collection Status
- Component Settings
- Tracing
- Application Topology
- URL Tracing
- Resource Tag Management
- Managing Tags
- Alarm Management
- AgentAgent Management
- Configuration Management
- System Management
- Change History
API Reference(2.0)
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
APM
- Querying the application list.
- Querying the Master Address
- Obtaining the AK/SK
- Searching for Components, Environments, and Agents in a Region
- Saving a Monitoring Item
- Querying the Monitoring Item List
- Querying All Agents of an Application
- Enabling or Disabling Collection for an Instance
- Deleting an Agent
- REGION
- CMDB
VIEW
- Querying Monitoring Item Configurations
- Querying the Trace Topology
- Querying Event Details
- Querying Span Data
- Obtaining All Data of a Trace
- Obtaining the Trend Graph
- Obtaining Summary Table Data
- Obtaining the Raw Data Table
- Obtaining Raw Data Details
- Obtaining the Instance Information
- Obtaining the Monitoring Item Information
- Obtaining the Details About a Monitoring Item
- AKSK
- ALARM
- TOPOLOGY
- TRANSACTION
- TRACING
APM
- Appendix
- Change History
- Best Practices(2.0)
- FAQs(2.0)
- Service Overview(1.0)
- Getting Started(1.0)
- Best Practices(1.0)
- User Guide
- API Reference
- SDK Reference
- General FAQs
- Consultation FAQs
Usage FAQs
- How Do I Obtain the AK/SK and Project ID?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Can I Do If No Data Is Found or the Data Is Abnormal?
- How Do I Connect APM to Non-Web Programs?
- How Are Tracing Time Lines Drawn?
- How Does APM Collect Probe Data?
- How Does APM Collect Mesh Data?
- How Do I Calculate the Number of Used Instances?
- How Do I Connect the JBoss Server in Standalone Mode to APM?
- What Can I Do If I Cannot Search for Logs Based on Trace IDs?
- How Do I Deploy APM Probes in CCE Containers?
- What Can I Do If the SSH Tunnel Process Is Abnormal?
- How Can I Do If No Topology or Data Is Displayed After the ICAgent and Java Probes Are Installed?
- Why Are Tomcat Thread Metrics Not Displayed on the JVM Monitoring Page?
- Why Is the Allocated Memory Greater Than the Preset Maximum Memory on the JVM Monitoring Page?
- How Do I Determine Whether an ICAgent Has Been Bound in CCE?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (2.0) (Kuala Lumpur Region)
Service Overview
- What Is APM
- Functions
- Basic Concepts
Metric Overview
- Metric Overview
- Exception
- Basic Monitoring
- GaussDB Database
- HBase Monitoring
- Jetcd Monitoring
- MySQL Database
- Oracle Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Data Collection
- Getting Started
User Guide
- Before You Start
- Application List
- CMDB Management
- Overview
- Tracing
- URL Tracing
- Managing Tags
- Alarm Management
- Agent Management
- System Management
- FAQs
- Change History
Service Overview
Collection Center
Collection Center displays collectors in a centralized manner. You can view and manage various collectors, metrics, and collection parameters supported by APM.
Viewing Collector Details
- Click
on the left and choose Application > Application Performance Management.
- In the navigation pane, choose Configuration Management > Collection Center.
All the supported collectors are displayed.
- In the collector list, click View Details in the Operation column in the row that contains the target collector. The collector details page is displayed.
Figure 1 Viewing collector details
- The collector details page consists of three modules: basic information, collection parameters, and metric set.
- Basic information
This module displays collector information such as collector name and type.
- Collection parameters
This module displays the custom parameter settings supported by the collector. The settings take effect after being delivered to JavaAgents and are used for custom collection.
- Metric sets
This module displays information about the metrics collected by the collector.
- Basic information
Collector
A collector is a plug-in for collecting metric data. It consists of the collector description, metric set, and collection parameters. Collector description describes the data collected by a collector. Metric set is the data collected according to specifications. Collection parameters are the custom data to be collected.
- Data is collected by APM Agents. For example, Java performance data is collected by JavaAgents. The data collected by APM Agents must correspond to the data models of collectors' metric sets so that servers can process the data.
- The Agent of each language and framework defines its own collector.
- After a collector is added to an environment, it is instantiated as a monitoring item. This process is generally automated. APM Agents automatically discover collection plug-ins used by applications and add collectors to the environment to form monitoring items. For example, if a Java application connects to a database through the JDBC driver for MySQL, the MySQL collector is automatically added to the environment to form a monitoring item.
Collection Parameters
Collectors corresponding to monitoring items define collection parameters. You can modify collection parameters on the page as required. These parameters will be delivered to Agents with heartbeat parameters to change collection behaviors. By default, Redis instruction content is not collected for security purposes. If necessary, modify collection parameters to collect specific instruction data. Collection parameters can also be defined on environment tags. Collectors automatically inherit collection parameter attributes of corresponding environment tags. In this way, configuration is automated. For details about how to set collection parameters, see Application Monitoring Configuration.
Metric Sets
A collector collects data of multiple metric sets. For example, the URL collector collects URL details, overall call condition, and status statistics. Each type of statistics corresponds to a metric set. Each metric set contains multiple metrics. For example, the metric set of URL details contains metrics such as the URL, method, number of calls, number of errors, and slowest call. Each metric corresponds to a data type.
Data Type |
Description |
Remarks |
ENUM |
Enumeration |
Primary key type. In the example of URL monitoring, the URL and method metrics are primary keys, and other metrics such as the number of calls correspond to the URL and method. |
INT |
Integer |
Maximum size: 8 bytes |
DOUBLE |
Floating-point number |
8-byte floating-point number |
STRING |
Character string |
Maximum length: 1,024 characters |
CLOB |
Large character string |
Maximum size: 1 MB |
DATETIME |
Time |
Time is automatically displayed on the page. |
