On this page
Performing Operations on Agents
Updated on 2024-12-25 GMT+08:00
Agent Management allows you to check the deployment and running statuses of the Agents that are connected to APM, and to stop, start, or delete them.
Viewing Agents
  2. Click on the left and choose Application > Application Performance Management.
  3. In the navigation pane, choose Application Monitoring > Agent Management.
  4. On the Agent management page, view the Agent list.
    1. In the upper left corner of the page, select a target region and application.
    2. Set the search criteria and click in the search box in the upper right corner of the page to filter Agents.
    Figure 1 Viewing Agents
The following table describes the Agent statuses.
Status
Enabled
The Agent is running properly.
Offline
The Agent is abnormal due to a network error. Check and restore the network.
Disabled
The Agent is manually or globally disabled. Contact technical support.
Batch Operations
  1. In the navigation pane, choose Application Monitoring > Agent Management.
  2. Select target objects and click Operation.
  3. Select Disable Agent, Enable Agent, or Delete Agent.
  4. In the dialog box that is displayed, click Yes to disable, enable, or delete the Agents for the selected hosts.
