Alarm Notification
Alarm notifications can be sent to specified personnel through emails, SMS, WeCom, DingTalk, Lark, HTTP, or HTTPS so that they can detect and handle faults in a timely manner, preventing loss. Ensure that you have the SMN permission. For details, see Permissions Management.
- If you do not create any notification object, no alarm notifications will be received. To view alarms, log in to the APM console and choose Alarm Center > Alarm List in the navigation pane.
Creating a Notification Object
- Log in to the APM console.
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- In the tree on the left, click an application. The metric details page of the application is displayed.
- Click the Notifications tab.
- Click Add. Figure 1 Creating a notification object
- On the displayed page, specify Region and Topic, and determine whether to enable default notification. If it is enabled, alarm notifications will be sent based on the topic and region you specify.
- If no topic is available, create one.
- If default notification is enabled, alarms will be sent to the specified region when you create an alarm policy.
- Click Yes.
