Updated on 2025-11-18 GMT+08:00
Alarm Policies
When you configure alarm rules for applications, you may have to perform the same operations multiple times. To solve this problem, APM supports the function of copying alarm rules across applications. You can copy the alarm rule of one application to other applications, which improves the configuration efficiency and consistency. The following will focus on using this function to reduce workload.
