Help Center/
Application Performance Management/
User Guide(2.0)/
Application Metric Monitoring/
Application Monitoring Configuration/
Configuration Details
Updated on 2025-03-20 GMT+08:00
You can define collection parameters for some collectors corresponding to monitoring items.
On the Monitoring Item tab page, only monitoring items related to the connected application are displayed.
Configuring a Monitoring Item
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- In the tree on the left, click
next to the target environment. The instance monitoring page is displayed. - Click the Monitoring Item tab.
- Locate the row that contains the target monitoring item and click Modify in the Operation column.
Figure 1 Configuring a monitoring item
- On the displayed page, edit the monitoring configuration. For details, see the corresponding section.
Figure 2 Editing the thread monitoring configuration
- Click Yes.
Enabling or Disabling a Monitoring Item
- Click
Figure 3 Enabling or disabling a monitoring item
- Locate the row that contains the target monitoring item and enable or disable it.
Parent topic: Application Monitoring Configuration
