Updated on 2026-02-25 GMT+08:00
Application List
Application List
The Applications page displays information such as components, environments, Agent status, and supported operations.
  1. Log in to the APM console.
  2. Click on the left and choose Application > Application Performance Management.
  3. In the navigation pane on the left, choose Application Monitoring > Applications.
    Figure 1 Application list
    Component|Environment: name of a component or environment. You can click the text in blue to go to the corresponding to component or environment page.
    Agent Status: number of Agents in different statuses.
    The following table describes the Agent statuses.
    Status
    Enabled
    The Agent is running properly.
    Offline
    • The Agent is offline due to network problems. Check and restore the network.
    • The Agent is offline if your process does not exist.
    • The Agent is disabled and offline if the trial period expires.
    Disabled
    The Agent is manually or globally disabled. Contact technical support.
More Operations
Perform the operations listed in Table 1 if needed.
Table 1 Related operations
Operation
Selecting an application
Select an application from the Application drop-down list on the left of the page.
Viewing the topology of an environment
Click Topology in the Operation column of an environment.
Setting a component or environment
Click Configure in the Operation column. On the displayed Instance tab page, set the component or environment as required.
Deleting an environment
Click Delete in the Operation column of an environment.
Searching for a component or environment
Enter a component or environment keyword or name on the right.
Back to APM 1.0
In the upper right corner of the page, click Back to APM 1.0.
Subscribing to Enterprise-Edition APM
After you subscribe to the enterprise-edition APM, preferential package information will be displayed. You can purchase preferential packages online.
  1. In the navigation pane on the left, choose Application Monitoring > Applications.
  2. Click Buy Package on the right. The Buy Package page is displayed.
  3. Select a region.
  4. Click a certain type of Agent package and click + or - to increase or decrease the number of packages as required. If needed, select Agent packages of multiple levels.
  5. Click Buy Now. The list of selected Agent packages is displayed.
  6. Read the APM Service Agreement and Privacy Statement and then select the checkbox to confirm that you have read them.
  7. Click Submit. The APM purchase information is displayed.
  8. Select a payment method and pay money.
    • The current edition is the enterprise edition. The pay-per-use price is $0.96 USD Agent × day. Select required preferential packages to save money.
    • The Agent quota of your preferential package will be used first. If the quota is used up or your package expires, APM will charge by your usage.
    • After you purchase a preferential package, it cannot be unsubscribed. After the package expires, you can continue using APM and your data is still secure.
    • Please complete the payment within three days. Otherwise, the order will be automatically canceled.
