Updated on 2026-07-29 GMT+08:00
Before You Start
This document describes how to use Application Performance Management (APM).
Application List
The Applications page displays information such as components, environments, Agent status, and supported operations.
CMDB Management
APM has built-in CMDB for managing the application structure and related configurations.
Application Metric Monitoring
APM can manage tags and monitor the metric data of JVM, GC, service calls, exceptions, external calls, database access, Profiler performance analysis, debugging diagnosis, and middleware, helping you comprehensively monitor application running.
Tracing
Information such as the call status, duration, and API is displayed, helping you further locate fault causes.
Application Topology
The call and dependency relationships between applications are displayed, and abnormal instances can be automatically discovered.
Application topologies are classified into single-component topologies, cross-application global topologies, and global application topologies.
Single-component topology: topology of a single component under an environment. You can also view the call relationships of direct and indirect upstream and downstream components.
Global application topology: topology of some or all components under an application.
Cross-application global topology: topology of all components under one or more applications.
URL Tracing
Through URL tracing, you can monitor the call relationships between important APIs and downstream services, and then detect problems more precisely.
Resource Tag Management
You can tag resources under your account for classification.
Managing Tags
You can add tags for different environments and applications for easy management.
Alarm Management
When an application connected to APM meets a preset alarm condition, an alarm is triggered and reported in a timely manner. In this way, you can quickly learn about service exceptions and rectify faults to prevent loss.
Agent Management
Agent Management allows you to check the deployment and running statuses of the Agents that are connected to APM, and to stop, start, or delete them.
Web Monitoring
APM Agents regularly collect performance metric data to measure the overall health of websites, HTML5 pages, and applets. They collect the data about loading performance, API requests, JS errors, access analysis, custom statistics, session tracing, scenario analysis, and network analysis, enabling you to monitor your websites.
Open Tracing
Open tracing collects complete traces of distributed applications and provides data about topologies, URLs, databases, and exceptions. Alarm policies can be customized as required. OpenTelemetry and SkyWalking support association with logs. Therefore, developers can quickly analyze and diagnose performance bottlenecks in the distributed application architecture and improve development and diagnosis efficiency of microservices.
App Monitoring
APM Agents regularly collect performance metric data to measure the overall health status of Android, iOS, and HarmonyOS apps. The collected data includes crashes, application not responding (ANR), errors, startup performance, network requests, devices, and custom statistics, helping you better monitor your app running.
System Management
System Management includes Collection Center, Data Masking, Usage Statistics, Access Keys, and General Configuration.
Collection Center: displays collectors in a centralized manner. You can view and manage various collectors, metrics, and collection parameters supported by APM.
Data Masking: You can set policies to mask the data reported using APM APIs.
Usage Statistics: After Agents are connected, you can check Agent Statistics on the Usage Statistics page.
Access Keys: long-term identity credentials. They ensure that the requests are secret, complete, and correct.
General Configuration: You can determine whether to collect data through bytecode instrumentation, and specify the slow request threshold and maximum number of rows to collect. You can also specify the slow SQL request threshold and set web monitoring aggregation.
Performance Monitoring
To improve user experience, APM provides performance monitoring, which addresses issues such as a lack of O&M view, difficult-to-use topology, and insufficient association analysis.
SDK Reference
APM provides different SDKs for connecting iOS, Android, HarmonyOS, Flutter, browser/HTML5, and applets.
Using IAM to Grant Access to APM
Enterprise Project Management Service (EPS) is used to control user access to APM resources.
CTS Auditing
Cloud Trace Service (CTS) auditing, which involves:
Recording APM operations: With CTS, you can record operations associated with cloud servers for future query, audit, and backtracking.
Querying APM operation records: After you enable CTS and create the management tracker, CTS starts recording operations on cloud resources.
Learn more
Getting Started
Learn how to connect applications to APM in different scenarios.
