- What's New
Service Overview(2.0)
- What Is APM
- Functions
- Application Scenarios
- Basic Concepts
- Edition Differences
- Permissions Management
Metric Overview
- Exception
- Basic Monitoring
- C3P0 Connection Pool Monitoring
- Cassandra Monitoring
- ClickHouse Database
- DBCP Connection Pool Monitoring
- Druid Connection Pool Monitoring
- EsRestClient Monitoring
- GaussDB Database
- HBase Monitoring
- Hikari Connection Pool Monitoring
- Jetcd Monitoring
- MongoDB Monitoring
- MySQL Database
- ObsClient Monitoring
- Oracle Database
- PostgreSQL Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Communication Protocol
- Privacy and Sensitive Information Protection Statement
- Data Collection
- Usage Restrictions
- Billing
- JavaAgent Updates
- Billing(2.0)
- Getting Started(2.0)
User Guide(2.0)
- Before You Start
- Application List
- CMDB Management
Application Metric Monitoring
- Overview
- Application Monitoring Details
Application Monitoring Configuration
- Configuration Details
- Configuring the MySQL Monitoring Item
- Configuring the HttpClient Monitoring Item
- Configuring the URL Monitoring Item
- Configuring the JavaMethod Monitoring Item
- Configuring the Druid Monitoring Item
- Configuring the ApacheHttpAsyncClient Monitoring Item
- Configuring the Redis Monitoring Item
- Configuring the Jedis Monitoring Item
- Configuring the HBase Monitoring Item
- Configuring the ApacheHttpClient Monitoring Item
- Configuring the Tomcat Monitoring Item
- Configuring the EsRestClient Monitoring Item
- Configuring the WebSocket Monitoring Item
- Configuring the KafkaProducer Monitoring Item
- Configuring the Hikari Monitoring Item
- Configuring the Exception Monitoring Item
- Configuring the Thread Monitoring Item
- Configuring the GC Monitoring Item
- Configuring the JVMInfo Monitoring Item
- Configuring the JVMMonitor Monitoring Item
- Configuring ProbeInfo Monitoring Item
- Monitoring Item Views
- Instance
- Collection Status
- Component Settings
- Tracing
- Application Topology
- URL Tracing
- Resource Tag Management
- Managing Tags
- Alarm Management
- AgentAgent Management
- Configuration Management
- System Management
- Change History
API Reference(2.0)
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
APM
- Querying the application list.
- Querying the Master Address
- Obtaining the AK/SK
- Searching for Components, Environments, and Agents in a Region
- Saving a Monitoring Item
- Querying the Monitoring Item List
- Querying All Agents of an Application
- Enabling or Disabling Collection for an Instance
- Deleting an Agent
- REGION
- CMDB
VIEW
- Querying Monitoring Item Configurations
- Querying the Trace Topology
- Querying Event Details
- Querying Span Data
- Obtaining All Data of a Trace
- Obtaining the Trend Graph
- Obtaining Summary Table Data
- Obtaining the Raw Data Table
- Obtaining Raw Data Details
- Obtaining the Instance Information
- Obtaining the Monitoring Item Information
- Obtaining the Details About a Monitoring Item
- AKSK
- ALARM
- TOPOLOGY
- TRANSACTION
- TRACING
APM
- Appendix
- Change History
- Best Practices(2.0)
- FAQs(2.0)
- Service Overview(1.0)
- Getting Started(1.0)
- Best Practices(1.0)
- User Guide
- API Reference
- SDK Reference
- General FAQs
- Consultation FAQs
Usage FAQs
- How Do I Obtain the AK/SK and Project ID?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Can I Do If No Data Is Found or the Data Is Abnormal?
- How Do I Connect APM to Non-Web Programs?
- How Are Tracing Time Lines Drawn?
- How Does APM Collect Probe Data?
- How Does APM Collect Mesh Data?
- How Do I Calculate the Number of Used Instances?
- How Do I Connect the JBoss Server in Standalone Mode to APM?
- What Can I Do If I Cannot Search for Logs Based on Trace IDs?
- How Do I Deploy APM Probes in CCE Containers?
- What Can I Do If the SSH Tunnel Process Is Abnormal?
- How Can I Do If No Topology or Data Is Displayed After the ICAgent and Java Probes Are Installed?
- Why Are Tomcat Thread Metrics Not Displayed on the JVM Monitoring Page?
- Why Is the Allocated Memory Greater Than the Preset Maximum Memory on the JVM Monitoring Page?
- How Do I Determine Whether an ICAgent Has Been Bound in CCE?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (2.0) (Kuala Lumpur Region)
Service Overview
- What Is APM
- Functions
- Basic Concepts
Metric Overview
- Metric Overview
- Exception
- Basic Monitoring
- GaussDB Database
- HBase Monitoring
- Jetcd Monitoring
- MySQL Database
- Oracle Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Data Collection
- Getting Started
User Guide
- Before You Start
- Application List
- CMDB Management
- Overview
- Tracing
- URL Tracing
- Managing Tags
- Alarm Management
- Agent Management
- System Management
- FAQs
- Change History
Service Overview
Topology
A topology graphically displays call and dependency relationships between applications. In a topology, each circle represents a service, each segment in a circle represents an instance, and each arrow represents a call relationship. APM supports calls between applications. The topology can display service call relationships across applications. When a circle represents an application, right-click the circle and choose View Application to go to the topology page.
Different colors on the circle represent different health statuses of instances. Colors are determined by Application Performance Index (Apdex) values. If an Apdex value is closer to 1, the corresponding application is healthier.
Topology Page
- Table 1 provides topology description.
Table 1 Topology description Color
Instance
Call
Green
0.75 ≤ Apdex ≤ 1
The instance responds quickly when it is called.
0.75 ≤ Apdex ≤ 1
Quick response.
Yellow
0.3 ≤ Apdex < 0.75
The instance responds slowly when it is called.
0.3 ≤ Apdex < 0.75
Slow response.
Red
0 ≤ Apdex < 0.3
The instance responds very slowly when it is called.
0 ≤ Apdex < 0.3
Very slow response.
Gray
The instance is not called.
N/A
Black
The instance is deleted.
N/A
- On the right of the topology page, set a time range to view the following topology details of an application:
- Transaction Apdex
- Top 5 services ranked by errors and latency
- Top 5 transactions ranked by errors and latency
- Top 5 SQL statements ranked by response time, calls, and errors
- In the topology, click a circle (a service) to view metric data, including Service Level Agreement (SLA) metrics, basic service metrics, and transaction details.
- In the topology, click a segment (an instance) in a circle to view metric data, including basic instance metrics, JVM metrics, node metrics, and transaction details.
Locating Faults Using the Topology
The following describes how to locate an instance with a slow response:
- Log in to the APM console.
- In the navigation pane, choose Topology.
- In the upper right corner of the topology page, set a time range during which a problem occurs.
- Check the instance with a long execution time (that is, the instance highlighted in red) in the topology.
- (Optional) For the service containing multiple instances, right-click the service and choose Expand from the shortcut menu to view call relationships between instances to preliminarily identify the abnormal instance.
- Choose Find Call-Chain from the shortcut menu. On the page that is displayed, further locate the fault based on call duration and other parameters.
Configuring Transaction Apdex Threshold
The response time of different transactions is different. APM enables you to configure different Apdex thresholds for different transactions. For example, if a login takes more than 50 ms, the response is slow. If a query transaction takes more than 10 ms, the response is slow. In this case, you need to set different Apdex thresholds for the login and query transactions.
- In the topology page, move the mouse cursor over a circle, right-click it, and click Edit Threshold.
- Modify the transaction Apdex threshold and click Apply.
