x-apigateway-authorizer
Meaning: Custom authorizer.
Scope of effect: Security Scheme Object
Example:
x-apigateway-authorizer:
auth_downgrade_enabled: false
authorizer_alias_uri: ''
authorizer_type: FUNC
authorizer_uri: >-
urn:fss:region:73d69ae0cfcf460190522d**********:function:default:DSFA
authorizer_version: latest
identities:
validation: ''
need_body: false
network_type: V2
retry_attempts: 0
timeout: 5000
ttl: 0
type: FRONTEND
Parameter |
Mandatory |
Type |
Description |
authorizer_type |
Yes |
String |
Value: FUNC |
authorizer_uri |
Yes |
String |
Function URN. |
auth_downgrade_enabled |
No |
Boolean |
Whether to enable the relaxed mode. The default value is false. |
authorizer_alias_uri |
No |
String |
Function alias address. If both the alias and version are specified, the version will be ignored and only the alias will be used. |
authorizer_version |
No |
String |
Function version. If both the alias and version are specified, the version will be ignored and only the alias will be used. Maximum length: 64 characters. |
need_body |
No |
Boolean |
Indicates whether to send the body. |
identities |
No |
Array of Identity objects |
Identity source. |
network_type |
No |
String |
Function network architecture:
Default value: V1. |
retry_attempts |
No |
Number |
Number of retries. |
timeout |
No |
Number |
Timeout. |
ttl |
No |
Number |
Cache TTL. |
type |
Yes |
String |
Custom authorizer type.
Parameter |
Mandatory |
Type |
Description |
name |
Yes |
String |
Parameter name. |
location |
Yes |
String |
Parameter location. |
validation |
No |
String |
Parameter verification expression. The default value is null, indicating that no verification is performed. |
