Updated on 2025-09-26 GMT+08:00
x-apigateway-auth-opt
Meaning: App (simple authentication) parameter
Scope of effect: Security Scheme Object (2.0)/Security Scheme Object (3.0)
Swagger example:
securityDefinitions:
  apig-auth-app:
    type: apiKey
    in: header
    x-apigateway-auth-type: AppSigv1
  apig-auth-app-header:
    type: apiKey
    in: header
    x-apigateway-auth-opt:
      appcode-auth-type: header
  apig-auth-iam:
    type: apiKey
    in: header
    x-apigateway-auth-type: IAM
OpenAPI example:
securitySchemes:
    apig-auth-app:
      in: header
      type: apiKey
      in: header
      type: apiKey
    apig-auth-iam:
      in: header
      type: apiKey
Table 1 Parameter description
Mandatory
Type
appcode-auth-type
No
String
Indicates whether AppCode authentication is enabled. The default value is disable.
  • disable: AppCode authentication is disabled.
  • header: AppCode authentication is enabled and the AppCode is located in the header.
