Configuring API Parameter Orchestration Rules
APIG supports API parameter orchestration. You can configure different algorithm rules to map new request parameters and values.
Creating an Orchestration Rule
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Policies.
- Click the Orchestration Rules tab.
- Click Create Rule and configure the parameters based on the following table.
Table 1 Rule configuration Parameter
Rule Name
Enter a rule name. Start with a letter and use only letters, digits, and underscores (_). 3 to 64 characters.
Orchestration Policy
Select a policy.
- list: Listed values are mapped to other values.
- range: Values in the range are mapped to other values.
- hash: Request header values are mapped to new ones after hash calculation.
- hash_range: hash values are generated using the request parameters for range orchestration.
- none_value: If the request parameter is empty, the mapping value of the none_value policy is returned.
- default: If request parameters cannot match any orchestration rule, the mapping value of the default policy is returned.
- head_n: Intercept the first n characters of the string (If n is greater than the length of the string, the complete parameter value is returned.) as a temporary parameter pending orchestration for the next rule.
- tail_n: Intercept the last n characters of the string (If n is greater than the length of the string, the complete parameter value is returned.) as a temporary parameter pending orchestration for the next rule.
Preprocessing
Mandatory when Orchestration Policy is set to list, range, hash, hash_range, head_n, or tail_n.
Whether the rule is a preprocessing one. A preprocessing rule generates a value as a temporary parameter pending orchestration for the next rule.
Parameter Name
Mandatory when Preprocessing is disabled or Orchestration Policy is set to none_value or default.
Enter the parameter name after orchestration. Start with a letter and use only letters, digits, and hyphens (-). 1 to 128 characters.
Parameter Type
Select a parameter type.
- string
- number
Parameter Location
Select a parameter location.
- header
- query
Mapping
Mandatory when Orchestration Policy is set to list, range, hash_range, none_value, or default.
Enter the mapping information. Start with a letter and use only letters, digits, underscores (_), and hyphens (-). 1 to 128 characters. Use commas (,) to separate multiple parameter values. A maximum of 3,000 parameters are supported.
You can click Add Mapping to add new mappings.
- Request Parameter Value Before Orchestration
- When Orchestration Policy is set to list, enter the request parameter value before orchestration.
- When Orchestration Policy is set to range or hash_range, enter the start value and end value of the range.
- Request Parameter Value After Orchestration: Enter the request parameter value after orchestration.
Length
Mandatory when Orchestration Policy is set to head_n or tail_n.
Length of the character string to be intercepted. The value ranges from 1 to 100.
- Click OK.
