Configuring Gateway Tags
Tags classify your gateways to facilitate search, analysis, and management.
You can search, analyze, and manage your resources on the Tag Management Service (TMS) console.
- Go to the APIG console.
- In the navigation pane, choose Gateways.
- Click Access Console or the name of the target gateway.
- On the Tags tab, click Add Tag.
A tag consists of a key and value. The value can be empty.
- The key can contain letters, digits, and spaces in UTF-8 format. The following special characters are also allowed: _.:=+-@. Do not enter tags starting with _sys_, which are system tags.
- The value can contain letters, digits, and spaces in UTF-8 format. The following special characters are also allowed: _.:=+-@
If your organization has configured tag policies for APIG, add tags to gateways based on the policies. If a tag does not comply with the policies, tag addition may fail. Contact your organization administrator to learn more about tag policies.
- Click OK.
Related Documents
Use the tags to filter, view, analyze, and manage your gateway resources on the TMS console.
- Hover over
on the left to expand the service list, and enter TMS. - On the TMS console, enter the required information to filter gateway resources.
- Region: Select the region where the gateway is.
- Resource Type: Select APIG.
- Resource Tag: Select a tag key.
