Help Center/ API Gateway/ User Guide/ Managing APIs/ Taking an API Offline
Updated on 2025-07-18 GMT+08:00
You can remove APIs that you do not need from the environments where the APIs have been published.
This operation will cause the APIs to be inaccessible in the environments. Ensure that you have notified users before this operation.
  • You have created an API group and API.
  • You have published the API in an environment.
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  3. In the navigation pane, choose API Management > API Groups.
  4. Click a group name to go to the Group Information page.
  5. On the APIs page, take APIs offline.
    • To take one API offline, select the API, and click Take Offline in the upper right.
    • To take multiple APIs (≤ 1000) offline, click Batch, select the APIs, and click the Take Offline icon.
  6. Select the environment from which you want to take the API offline, and click Yes.
Follow-Up Operations
After taking an API offline, delete it to release resources.
