Help Center/ API Gateway/ User Guide/ (Optional) Configuring Authorization for API Calling/ Configuring AppCodes for Simple Authentication
Updated on 2025-07-18 GMT+08:00
AppCodes are identity credentials of a credential used to call APIs in simple authentication mode. In this mode, the X-Apig-AppCode parameter (whose value is an AppCode on the credential details page) is added to the HTTP request header for quick response. APIG verifies only the AppCode and the request content does not need to be signed.
When an API is called using app authentication and simple authentication is enabled for the API, the key and secret can be used to sign and verify the API request. AppCodes can also be used for simple authentication.
Precautions
Simple authentication does not require complex signature processes. However, the AppCode is transmitted in plaintext, which may bring security risks. Therefore, do not carry privacy information.
  • You have created an API using app authentication and enabled simple authentication. If no, create it by referring to Creating an API. After you enable simple authentication for an existing API, you need to publish the API again to make the configuration take effect.
  • You have created a credential and bind it to an API that uses app authentication. If no, create it by referring to Configuring Authentication Credentials.
  • For security purposes, simple authentication only supports API calls over HTTPS or gRPCS.
  • You can create a maximum of five AppCodes for each credential.
Generating an AppCode
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > Credentials.
  1. Click the name of the target credential.
  2. Under AppCodes, click Add AppCode.
  3. Configure the AppCode in the dialog box based on the following table.
    Table 1 AppCode configuration
    AppCode Type
    Select the method for generating an AppCode.
    • Automatically generated: An AppCode is generated by the system.
    • Custom: Specify an AppCode.
    AppCode
    Enter an AppCode if you set AppCode Type to Custom. Enter 64 to 180 characters, starting with a letter, digit, plus sign (+), or slash (/). Only letters, digits, and the following special characters are allowed: +_!@#$%-/=
  4. Click OK.
  5. After the AppCode is added, you can use it for simple authentication of API requests.
    When sending a request, add the X-Apig-AppCode parameter to the request header and omit the request signature.
    For example, when using curl, add the X-Apig-AppCode parameter to the request header and set the parameter value to the generated AppCode.
    curl -X GET "https://api.exampledemo.com/testapi" -H "content-type: application/json"  -H "host: api.exampledemo.com" -H "X-Apig-AppCode: xhrJVJKABSOxc7d***********FZL4gSHEXkCMQC"
Video Tutorial
This video will show you how to call an API through simple authentication.
