API Authorization Overview
When calling an API that uses App authentication, API callers can use credentials or AppCodes for simple API authentication. The following table lists the app authentication types. For more information, see Calling an Open API.
Type |
Authentication Mode |
Signature authentication |
Credential |
Simple authentication |
AppCode |
Two-way authentication |
Credential/AppCode and custom authentication |
app_api_key authentication |
Credential |
app_secret authentication |
Credential |
app_basic authentication |
Credential |
app_jwt authentication |
Credential |
- Configuring Authentication Credentials
Create a credential to generate a key/secret pair. When an API is called, APIG authenticates the identity based on the key/secret pair. The key is unique and cannot be reset. The secret can be reset.
- Configuring AppCodes for Simple Authentication
After the simple authentication is configured, APIG can perform authentication based on the AppCode or key/secret pair when calling the API.
