Request Throttling 2.0
Updated on 2025-01-24 GMT+08:00
A request throttling 2.0 policy limits the number of times that an API can be called within a specific time period. Parameter-based, basic, and excluded throttling is supported.
  • Basic throttling
    Throttle requests by API, user, credential, or source IP address. This function is equivalent to a traditional request throttling policy (see Configuring API Request Throttling) but is incompatible with it.
  • Parameter-based throttling
    Throttle requests based on headers, path parameter, method, query strings, or system parameters.
  • Excluded throttling
    Throttle requests based on specific credentials or tenants.
If your gateway does not support this policy, submit a service ticket to upgrade the gateway to the latest version.
  • An API can be bound with only one request throttling 2.0 policy for a given environment, but each request throttling 2.0 policy can be bound to multiple APIs.
  • A request throttling policy becomes invalid if a request throttling 2.0 policy is bound to the same API as the existing one.
  • You can define a maximum of 100 parameter-based throttling rules. The parameter name can contain 1 to 32 characters.
  • The policy content cannot exceed 65,535 characters.
  • Policy parameters will be stored as plaintext. To prevent information leakage, do not contain sensitive information in these parameters.
  • Policies are independent of APIs. A policy takes effect for an API only after they are bound to each other. When binding a policy to an API, you must specify an environment where the API has been published. The policy takes effect for the API only in the specified environment.
  • After you bind a policy to an API, unbind the policy from the API, or update the policy, you do not need to publish the API again.
  • Taking an API offline does not affect the policies bound to it. The policies are still bound to the API if the API is published again.
  • Policies that have been bound to APIs cannot be deleted.
Creating a Request Throttling 2.0 Policy
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > API Policies.
  2. On the Policies tab, click Create Policy.
  3. On the Select Policy Type page, select Request Throttling 2.0 in the Plug-ins area.
  4. Set the policy information based on the following table.
    Table 1 Request throttling 2.0 parameters
    Name
    Enter a policy name. Using naming rules facilitates future search.
    It can contain 3 to 255 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
    Type
    Fixed as Request Throttling 2.0.
    Description about the plug-in. Enter 1 to 255 characters.
    Policy Content
    Content of the plug-in, which can be configured in a form or using a script.
    Throttling
    High-performance throttling is recommended.
    • High precision: better for low concurrency scenarios (performance is affected)
    • High performance: better for medium concurrency scenarios (performance is less affected, with small occasional errors)
    • Single node: better for high concurrency scenarios (request throttling within each node; performance is least affected, with small occasional errors)
    Policy Type
    • API-specific
      Monitor and control the requests for a single API.
    • API-sharing
      Monitor and control requests for all APIs bound with the policy.
    Period
    The throttling can be accurate to the second, minute, hour, or day.
    • Max. API Requests: Limit the maximum number of times an API can be called within a specific period.
    • Max. User Requests: Limit the maximum number of times an API can be called by a user within a specific period.
    • Max. Credential Requests: Limit the maximum number of times an API can be called by a credential within a specific period.
    • Max. IP Address Requests: Limit the maximum number of times an API can be called by an IP address within a specific period.
    Max. API Requests
    The maximum number of times each bound API can be called within the specified period.
    This parameter must be used together with Period.
    Max. User Requests
    The maximum number of times each bound API can be called by a user within the specified period. For APIs with IAM authentication, the throttling is based on a project ID; for APIs with app authentication, the throttling is based on an account ID. For details about account ID and project ID, see the description about Excluded Tenants in this table.
    • The value of this parameter cannot exceed that of Max. API Requests.
    • This parameter must be used together with Period.
    • If there are many users under your account that access an API, the request throttling limits of the API will apply to all these users.
    The maximum number of times each bound API can be called by a credential within the specified period. This limit only applies to APIs that are accessed through app authentication.
    The maximum number of times each bound API can be called by an IP address within the specified period. You can configure the real_ip_from_xff parameter of the gateway to use the IP address in the X-Forwarded-For header as the basis for request throttling.
    Parameter-based Throttling
    Enable or disable parameter-based throttling. After this function is enabled, API requests are throttled based on the parameters you set.
    Parameters
    Define parameters for rule matching.
    • Parameter Location: the location of a parameter used for rule matching.
      • path: API request URI. This parameter is configured by default.
      • method: API request method. This parameter is configured by default.
      • header: the key of a request header. For security purposes, do not include sensitive information in these parameters.
      • query: the key of a query string.
      • system: a system parameter.
    • Parameter: the name of a parameter to match the specified value in a rule.
    Rules
    Define throttling rules. A rule consists of conditions, an API request throttling limit, and a period.
    To add more rules, click Add Rule.
    • Rule
      Click to set condition expressions. To set an expression, select a parameter and operator, and enter a value.
      • =: equal to
      • !=: not equal to
      • pattern: regular expression
      • enum: enumerated values. Separate them with commas (,).
    • Max. API Requests
      The maximum number of times that an API can be called within a specific time period.
    • Period
      A period of time that will apply with the throttling limit you set. If this parameter is not specified, the period set in the Police Information area will be used.
    For example, configure parameter-based throttling as follows: add the Host parameter and specify the location as header; add the condition Host = www.abc.com, and set the throttling limit to 10 and the period to 60s. For APIs whose Host parameter in the request header is equal to www.abc.com, they cannot be called again once called 10 times in 60s.
    Excluded Throttling
    Enable or disable excluded throttling. After this function is enabled, the throttling limits for excluded tenants and credentials override the Max. User Requests and Max. Credential Requests set in the Basic Throttling area.
    Excluded Tenants
    Tenant ID: an account ID or project ID.
    Threshold: the maximum number of times that a specific tenant can access an API within the specified period. The threshold cannot exceed the value of Max. API Requests in the Basic Throttling area.
    Excluded Credentials
    Select a credential, and specify the maximum number of times that the credential can access an API within the specified period. The threshold cannot exceed the value of Max. API Requests in the Basic Throttling area.
  5. Click OK.
    To clone this policy, click Clone in the Operation column. The name of a cloned policy cannot be the same as that of any existing policy.
  6. After the policy is created, perform the operations described in Binding the Policy to APIs to apply the policy for the API.
Example Script
  "scope": "basic",
  "default_interval": 60,
  "default_time_unit": "second",
  "api_limit": 100,
  "app_limit": 50,
  "user_limit": 50,
  "ip_limit": 20,
  "specials": [
      "type": "app",
      "policies": [
          "key": "e9230d70c749408eb3d1e838850cdd23",
          "limit": 10
      "type": "user",
      "policies": [
          "key": "878f1b87f71c40a7a15db0998f358bb9",
          "limit": 10
  "algorithm": "counter",
  "parameters": [
      "id": "3wuj354lpptv0toe0",
      "value": "reqPath",
      "type": "path",
      "name": "reqPath"
      "id": "53h7e7j11u38l3ocp",
      "value": "method",
      "type": "method",
      "name": "method"
      "id": "vv502bnb6g40td8u0",
      "value": "Host",
      "type": "header",
      "name": "Host"
  "rules": [
      "match_regex": "[\"Host\",\"==\",\"www.abc.com\"]",
      "rule_name": "u8mb",
      "time_unit": "second",
      "interval": 2,
      "limit": 5
  1. Click the policy name to go to the policy details page.
  2. Select an environment and click Select APIs.
  3. Select the API group, environment, and required APIs.
    APIs can be filtered by API name or tag. The tag is defined during API creation.
  4. Click OK.
    • If an API no longer needs this policy, click Unbind in the row that contains the API.
    • If there are multiple APIs that no longer need this policy, select these APIs, and click Unbind above the API list. You can unbind a policy from a maximum of 1000 APIs at a time.
