Response Headers
The following table describes the response headers that APIG adds to the response returned when an API is called.
X-Apig-Mode: debug indicates API debugging information.
Response Header |
Description |
X-Request-Id |
Request ID. Returned for all valid requests. |
X-Apig-Latency |
Duration from the time when APIG receives a request to the time when the backend returns a message header. Returned only when the request header contains X-Apig-Mode: debug. |
X-Apig-Upstream-Latency |
Duration from the time when APIG sends a request to the backend to the time when the backend returns a message header. Returned only when the request header contains X-Apig-Mode: debug and the backend type is not Mock. |
X-Apig-RateLimit-api |
API request limit information. Example: remain:9,limit:10,time:10 second. Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called. |
X-Apig-RateLimit-user |
User request limit information. Example: remain:9,limit:10,time:10 second. Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by a user. |
X-Apig-RateLimit-app |
Credential request limit information. Example: remain:9,limit:10,time:10 second. Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by a credential. |
X-Apig-RateLimit-ip |
IP address request limit information. Example: remain:9,limit:10,time:10 second. Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by an IP address. |
X-Apig-RateLimit-api-allenv |
Default API request limit information. Example: remain:199,limit:200,time:1 second. Returned only when the request header contains X-Apig-Mode: debug. |
X-Apig-count |
Total number of times that a request is forwarded by APIG. Returned for all valid requests forwarded by APIG. If the value of X-Apig-count is greater than 10, error APIG.0612 is reported. |
