Monitoring Metrics
Updated on 2025-01-10 GMT+08:00
Introduction
This section describes the metrics that APIG reports to the Cloud Eye service. You can view metrics and alarms by using the Cloud Eye console.
Namespace
SYS.APIC
Metrics
Table 1 Metric description
Metric ID
Metric Name
Value Range
Monitored Object and Dimension
Monitoring Period (Minute)
requests
API Calls
Number of times that all APIs in a dedicated gateway have been called.
≥ 0
Monitored object: dedicated API gateway
Dimension: instance_id
error_4xx
4xx Errors
Number of times that all APIs in the dedicated gateway return a 4xx error.
≥ 0
error_5xx
5xx Errors
Number of times that all APIs in the dedicated gateway return a 5xx error.
≥ 0
throttled_calls
Throttled API Calls
Number of times that all APIs in the dedicated gateway have been throttled.
≥ 0
avg_latency
Average Latency
Average latency of all APIs in the gateway.
≥ 0
Unit: ms
max_latency
Maximum Latency
Maximum latency of all APIs in the gateway.
≥ 0
Unit: ms
req_count
Requests
Number of times that an API has been called.
≥ 0
Monitored object: API
Dimension: api_id
req_count_2xx
2xx Responses
Number of times that the API returns a 2xx response.
≥ 0
Dimension: api_id
req_count_4xx
4xx Errors
Number of times that the API returns a 4xx error.
≥ 0
Dimension: api_id
req_count_5xx
5xx Errors
Number of times that the API returns a 5xx error.
≥ 0
Dimension: api_id
req_count_error
Total Errors
Total number of errors returned by the API.
≥ 0
Dimension: api_id
avg_latency
Average Latency
Average latency of the API.
≥ 0
Unit: ms
Dimension: api_id
max_latency
Maximum Latency
Maximum latency of the API.
≥ 0
Unit: ms
Dimension: api_id
input_throughput
Incoming Traffic
Incoming traffic of the API.
≥ 0
Unit: Byte, KB, MB, or GB
Dimension: api_id
output_throughput
Outgoing Traffic
Outgoing traffic of the API.
≥ 0
Dimension: api_id
node_system_load
Node System Load
Load details of a gateway node on the data plane. 1 means low water level, 2 means medium water level, and 3 means high water level.
1, 2, 3
Unit: count
Monitored object: gateway node
Dimension: node_ip
node_cpu_usage
Node CPU Usage
CPU usage details of a gateway node on the data plane.
≥ 0
Unit: %
Dimension: node_ip
node_memory_usage
Node Memory Usage
Memory usage details of a gateway node on the data plane.
≥ 0
Unit: %
Dimension: node_ip
Dimension
Table 2 Monitoring dimensions
Key
Value
instance_id
Dedicated gateway
instance_id,node_ip
Dedicated gateway node
instance_id,api_id
API
