- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Using IAM to Grant Access to AOM
Connecting to AOM
- Connecting to AOM
- Managing Collector Base UniAgent
- Connecting Businesses to AOM
- Connecting Applications to AOM
Connecting Middleware and Custom Plug-ins to AOM
- Overview About Middleware and Custom Plug-in Connection to AOM
Connecting Middleware to AOM
- Ingesting MySQL Metrics to AOM
- Ingesting Redis Metrics to AOM
- Ingesting Kafka Metrics to AOM
- Ingesting Nginx Metrics to AOM
- Ingesting MongoDB Metrics to AOM
- Ingesting Consul Metrics to AOM
- Ingesting HAProxy Metrics to AOM
- Ingesting PostgreSQL Metrics to AOM
- Ingesting Elasticsearch Metrics to AOM
- Ingesting RabbitMQ Metrics to AOM
- Ingesting Other Middleware Metrics to AOM
- Connecting Custom Plug-ins to AOM
- Managing Middleware and Custom Plug-in Collection Tasks
- Connecting Running Environments to AOM
- Connecting Cloud Services to AOM
- Connecting Open-Source System to AOM
- Managing Log Ingestion
(New) Connecting to AOM
- AOM Access Overview
- Connecting Components to AOM
- Overview About Middleware Connection to AOM
- Managing Middleware Collection Tasks
- Ingesting Data to AOM Using Open-Source APIs and Protocols
- Managing Metric and Log Ingestion
- Observability Metric Browsing
- Dashboard Monitoring
- Alarm Monitoring
- (New) Log Management
- Log Management (Old)
Prometheus Monitoring
- Prometheus Monitoring Overview
- Managing Prometheus Instances
- Managing Prometheus Instance Metrics
- Using Prometheus Monitoring to Monitor CCE Cluster Metrics
- Configuring Multi-Account Aggregation for Unified Monitoring
- Configuring Metric Collection Rules for CCE Clusters
- Configuring Recording Rules to Improve Metric Query Efficiency
- Configuring Data Multi-Write to Dump Metrics to Self-Built Prometheus Instances
- Setting Metric Storage Duration
- Monitoring Prometheus Instance Metrics Through Dashboards
- Configuring the Remote Read Address to Enable Self-built Prometheus to Read Data from AOM
- Configuring the Remote Write Address to Report Self-Built Prometheus Data to AOM
- Checking Prometheus Instance Data Through Grafana
- Checking the Number of Metric Samples Reported by Prometheus Instances
- Infrastructure Monitoring
- Application Insights
- O&M Management
- Global Settings
- Querying AOM Traces
- Migrating Data from AOM 1.0 to AOM 2.0
Best Practices
- AOM Best Practices
- Building a Comprehensive Metric System
- Alarm Noise Reduction
- Unified Metric Monitoring
- Customizing OS Images to Automatically Connect UniAgent
- Connecting Self-Built Middleware in the CCE Container Scenario
- Interconnecting Third-Party/IDC/Huawei Cloud Cross-Region Self-Built Prometheus with AOM Prometheus Instances
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
- Querying the Event Alarm Rule List
- Adding an Event Alarm Rule
- Modifying an Event Alarm Rule
- Deleting an Event Alarm Rule
- Querying Events and Alarms
- Counting Events and Alarms
- Reporting Events and Alarms.
- Obtaining the Alarm Sending Result
- Deleting a Silence Rule
- Adding a Silence Rule
- Modifying a Silence Rule
- Obtaining the Silence Rule List
- Querying an Alarm Action Rule Based on Alarm Rule Name
- Adding an Alarm Action Rule
- Deleting an Alarm Action Rule
- Modifying an Alarm Action Rule
- Querying the Alarm Action Rule List
- Querying Metric or Event Alarm Rules
- Adding or Modifying Metric or Event Alarm Rules
- Deleting Metric or Event Alarm Rules
Monitoring
- Querying Time Series Objects
- Querying Time Series Data
- Querying Metrics
- Querying Monitoring Data
- Adding Monitoring Data
- Adding or Modifying One or More Service Discovery Rules
- Deleting a Service Discovery Rule
- Querying Existing Service Discovery Rules
- Adding a Threshold Rule
- Querying the Threshold Rule List
- Modifying a Threshold Rule
- Deleting a Threshold Rule
- Querying a Threshold Rule
- Deleting Threshold Rules in Batches
- Querying Expression Calculation Results in a Specified Period Using the GET Method
- (Recommended) Querying Expression Calculation Results in a Specified Period Using the POST Method
- Querying the Expression Calculation Result at a Specified Time Point Using the GET Method
- (Recommended) Querying Expression Calculation Results at a Specified Time Point Using the POST Method
- Querying Tag Values
- Obtaining the Tag Name List Using the GET Method
- (Recommended) Obtaining the Tag Name List Using the POST Method
- Querying Metadata
- Log
- Prometheus Instance
- Configuration Management
CMDB (AOM 2.0)
- Creating an Application
- Deleting an Application
- Querying the Details of an Application
- Modifying an Application
- Adding a Component
- Deleting a Component
- Querying the Details of a Component
- Modifying a Component
- Creating an Environment
- Deleting an Environment
- Querying the Details of an Environment
- Modifying an Environment
- Querying the Resource List of a Node
- Querying the Details of an Application Based on the Application Name
- Querying the Details of an Environment Based on the Environment Name
- Querying the Details of a Component Based on the Component Name
- Adding a Sub-application
- Deleting a Sub-application
- Modifying a Sub-application
Automation (AOM 2.0)
- Creating a Task
- Updating a Task
- Operating a Paused Task
- Obtaining the Execution Details of a Workflow
- Terminating a Task
- Querying a Script
- Querying the Script Version
- Performing Fuzzy Search on the Job Management Page
- Querying Execution Plans (Custom Templates) Based on Job ID
- Querying the Details of an Execution Plan
- Querying Tasks
- Querying the Execution History of a Task
- Executing a Workflow
Alarm
- Historical APIs
- Examples
- Appendix
- SDK Reference
- Dashboard
- Alarm Management
- Log Analysis
- Application Monitoring
Collection Management
- Are ICAgent and UniAgent the Same?
- What Can I Do If an ICAgent Is Offline?
- Why Is an Installed ICAgent Displayed as "Abnormal" on the UniAgent Installation and Configuration Page?
- Why Can't I View the ICAgent Status After It Is Installed?
- Why Can't AOM Monitor CPU and Memory Usage After ICAgent Is Installed?
- How Do I Obtain an AK/SK?
- FAQs About UniAgent and ICAgent Installation
- How Do I Enable the Nginx stub_status Module?
- Why Does APM Metric Collection Fail?
- Why Cannot the Installation Script Be Downloaded When I Try to Install UniAgent on an ECS?
- CMDB (Unavailable Soon)
O&M Management (Unavailable Soon)
- How Can I Obtain the OBS Permission for Installing Packages?
- Why Can't Scheduled Tasks Be Triggered?
- Can I Specify Script Parameters and Hosts During Job Execution?
- Why Is a Parameter Error Displayed When I Create a Scheduled Task Using a Cron Expression?
- How Can I Set a Review for an Execution Plan?
- Why Is "delete success:{}" Displayed (Files Cannot Be Deleted) During Disk Clearance?
- What Can I Do If the Execution Plan Is Not Updated After I Modify the Job?
- What Can I Do If "agent not found" Is Displayed?
- Why Are the Hosts Listed in Execution Logs Inconsistent with Those I Configured for a Task?
- Why Did a Task Fail to Execute?
- Other FAQs
- Videos
AOM 1.0 Documentation
Service Overview (1.0)
- What Is AOM?
- Product Architecture
- Functions
- Application Scenarios
- Edition Differences
Metric Overview
- Introduction
- Network Metrics and Dimensions
- Disk Metrics and Dimensions
- Disk Partition Metrics
- File System Metrics and Dimensions
- Host Metrics and Dimensions
- Cluster Metrics and Dimensions
- Container Metrics and Dimensions
- VM Metrics and Dimensions
- Instance Metrics and Dimensions
- Service Metrics and Dimensions
- Security
- Restrictions
- Privacy and Sensitive Information Protection Statement
- Relationships Between AOM and Other Services
- Basic Concepts
- Permissions
- Billing
- Change History
- Getting Started (1.0)
User Guide (1.0)
- Overview
- Subscribing to AOM
- Permissions Management
- Connecting Resources to AOM
- Monitoring Overview
- Alarm Management
- Resource Monitoring
- Log Management
- Resource Groups
- Auditing
- Upgrading to AOM 2.0
- Best Practices (1.0)
FAQs (1.0)
- User FAQs
Consultation FAQs
- What Is the Billing Policy of AOM?
- What Are the Usage Restrictions of AOM?
- What Are the Differences Between AOM and APM?
- How Do I Distinguish Alarms from Events?
- What Is the Relationship Between the Time Range and Statistical Cycle?
- Does AOM Display Logs in Real Time?
- Will Container Logs Be Deleted After They Are Dumped?
- How Can I Do If I Cannot Receive Any Email Notification After Configuring a Threshold Rule?
- Why Are Connection Channels Required?
Usage FAQs
- What Can I Do If I Do Not Have the Permission to Access SMN?
- What Can I Do If Resources Are Not Running Properly?
- How Do I Set the Full-Screen Online Duration?
- What Can I Do If the Log Usage Reaches 90% or Is Full?
- How Can I Check Whether a Service Is Available?
- Why Is the Status of an Alarm Rule Displayed as "Insufficient"?
- Why the Status of a Workload that Runs Normally Is Displayed as "Abnormal" on the AOM Page?
- How Do I Create the apm_admin_trust Agency?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Is the Billing Policy of Logs?
- Why Can't I See Any Logs on the Console?
- Why Can't the Host Be Monitored After ICAgent Is Installed?
- Why Is "no crontab for root" Displayed During ICAgent Installation?
- Why Can't I Select an OBS Bucket When Configuring Log Dumping on AOM?
- Why Can't Grafana Display Content?
More Documents
User Guide (1.0) (Kuala Lumpur Region)
Service Overview
- What Is AOM?
- Functions
Metric Overview
- Introduction
- Restrictions
- Basic Concepts
- Permissions
- Getting Started
- Alarm Management
- Log Management
- Auditing
- User FAQs
Consultation FAQs
Usage FAQs
- Change History
Service Overview
User Guide (2.0) (Kuala Lumpur Region)
- Getting Started
- Introduction
- Access Center
- Dashboard
- Alarm Management
Metric Analysis
- Metric Browsing
- Resource Usage Statistics
- Log Analysis (Beta)
- Container Insights
- Process Monitoring
- Collection Management
- Remarks
- Auditing
- Overview
- Dashboard
- Alarm Management
- Log Analysis
- Why Is an Installed ICAgent Displayed as "Abnormal" on the Agent Management Page?
- FAQs About ICAgent Installation
- Other FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
- Querying an Alarm Action Rule Based on Rule Name
Monitoring
- Querying Metrics
- Log
Alarm
- Examples
- Appendix
- Change History
- Getting Started
- User Guide
- Obtaining an AK/SK
- How Can I Do If I Do Not Have the Permission to Access SMN?
- How Do I Distinguish Alarms and Events?
- Why the Status of a Workload that Runs Normally Is Abnormal on the AOM Page?
API Reference(ME-Abu Dhabi Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Adding or Modifying One or More Application Discovery Rules
- Deleting an Application Discovery Rule
- Querying Application Discovery Rules
- Auto Scaling
- Log
Monitoring (v1)
- Appendix
User Guide (Ankara Region)
- Getting Started
- User Guide
- Why Is the Application Status Normal but the Component Status Abnormal?
- Best Practices
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Monitoring (v2)
- Auto Scaling
- Log
- Events/Alarms
- Agent
- Application Discovery Rules
- Querying Metadata
- Querying the Calculation Results of a PromQL Expression in a Specified Period Based on Prometheus Instance
- Querying the Calculation Result of a PromQL Expression at a Specified Time Point Based on Prometheus Instance
- Querying the Values of a Tag Based on Prometheus Instance
- Obtaining the Tag Name List Based on Prometheus Instance
- Querying Metadata Based on Prometheus Instance
Monitoring (v1)
- Appendix
- Change History
Show all
Configuring a Proxy Area and Proxy
To enable network communication between different clouds, purchase a Huawei Cloud ECS, set the ECS to a proxy, and bind an EIP to it. AOM then delivers deployment and control instructions to remote hosts and receives O&M data through the proxy. A proxy area is used to manage proxies by category. It consists of multiple proxies.
- Log in to the AOM 2.0 console.
- In the navigation pane, choose Settings. The Global Configuration page is displayed.
- In the navigation tree on the left, choose Collection Settings > Proxy Areas. The Proxy Areas page is displayed.
- Click Add Proxy Area and set proxy area parameters.
Table 1 Proxy area parameters Parameter
Example
Proxy Area Name
Name of a proxy area. Max.: 64
test
Network Type
Options: Inner and Public. The default value is Inner.
Inner
- Click OK to add a proxy area.
- Locate the new proxy area, click Add Proxy, and set proxy parameters.
Table 2 Proxy parameters Parameter
Example
Proxy Area
Select a proxy area that you have created.
qwsertyddfsdfdf
Host
Select a host where the UniAgent has been installed.
Proxy IP Address
Set the IP address of the proxy.
Port
Enter a port number, which cannot be greater than 65535.
- Click OK. The proxy is added.
After configuring the proxy area and proxy, perform the following operations if needed:
Table 3 Managing the proxy area and proxy Operation
Searching for a proxy area
Click
next to Add Proxy Area. Then, in the search box, enter a keyword to search for your target proxy area.
Modifying a proxy area
Hover the pointer over a proxy area and choose
> Edit. In the dialog box that is displayed, enter a new name, select a network type, and click OK.
Deleting a proxy area
> Delete. In the dialog box that is displayed, click Yes to delete the proxy area.
Checking a proxy
Click a proxy area to check the proxy in it.
Modifying a proxy IP address
Click Modify Proxy IP in the Operation column of the proxy. On the page that is displayed, modify the proxy IP address.
Deleting a proxy
Click Delete in the Operation column of the proxy. In the displayed dialog box, click OK to delete the proxy.
