Managing UniAgents
Updated on 2025-03-03 GMT+08:00
After UniAgents are installed, you can reinstall, upgrade, uninstall, or delete them when necessary.
  • If the host where a UniAgent is installed using the old method runs Windows, you need to manually reinstall the UniAgent.
  • UniAgents will not be automatically upgraded. Manually upgrade them if needed.
  • If the host where a UniAgent is installed using the old method runs Windows, you need to manually uninstall the UniAgent.
Reinstalling UniAgents
Reinstall UniAgents when they are in the Abnormal, Installation failed, or Not installed state.
  1. Log in to the AOM 2.0 console.
  2. In the navigation pane, choose Settings. The Global Configuration page is displayed.
  3. In the navigation pane, choose Collection Settings > UniAgent Installation and Configuration.
  4. Select one or more servers where UniAgents are to be reinstalled and perform the following operations:
    • (Old) On the VM Access page, choose UniAgent Batch Operation > Reinstall. On the displayed page, reinstall UniAgents as prompted.
    • (New) On the UniAgent Installation and Configuration page, switch to the ECS or Other tab page and click Reinstall. On the displayed page, reinstall UniAgents as prompted.
Upgrading UniAgents
Upgrade your UniAgent to a more reliable, stable new version.
  2. In the navigation pane, choose Settings > Collection Settings > UniAgent Installation and Configuration.
  3. Select one or more servers where UniAgents are to be upgraded and perform the following operations:
    • (Old) On the VM Access page, choose UniAgent Batch Operation > Upgrade. On the displayed page, select the target version and click OK.
    • (New) On the UniAgent Installation and Configuration page, switch to the ECS or Other tab page and click Upgrade. On the displayed page, select the target version and click OK.
    Wait for about 1 minute until the UniAgent upgrade is complete.
Uninstalling UniAgents
Uninstall UniAgents when necessary.
  3. Select one or more servers where UniAgents are to be uninstalled and perform the following operations:
    • (Old) On the VM Access page, choose UniAgent Batch Operation > Uninstall. On the displayed page, click OK.
    • (New) On the UniAgent Installation and Configuration page, switch to the ECS or Other tab page and click Uninstall. On the displayed page, click OK.
    You can also log in to the target server as the root user and run the following command to uninstall the UniAgent:
    bash /usr/local/uniagentd/bin/uninstall_uniagent.sh;
Deleting UniAgents
Delete the UniAgents that are not used or cannot be used according to the following procedure:
  3. Select one or more servers where UniAgents are to be deleted and perform the following operations:
    • (Old) On the VM Access page, choose UniAgent Batch Operation > Delete. On the displayed page, click OK.
    • (New) On the UniAgent Installation and Configuration page, switch to the Other tab page and click Delete. On the displayed page, click OK. (Only the hosts on the Other tab page support UniAgent deletion.)
