Updated on 2025-09-03 GMT+08:00
Scenario Overview
Released tool cards are displayed based on scenarios described in Checking Scenarios. You can use the cards to quickly create tasks, add the cards to favorites, or remove them from the tool market. To prevent a card from being removed, follow the instructions provided in Custom Policies for Automation. For details, see Table 1.
Table 1 Related operations
Operation
Adding a card to favorites
Click to add a card to favorites.
Removing a card
Click in the upper right corner of a card and choose Remove.
  • Before removing a service, check whether it has been referenced by a scheduled O&M scenario. If yes, delete the scenario first. For details, see Reference Details.
  • After a card is removed, it will not be displayed on the Scenarios page. In addition, the card will also be removed from the tool market, and the status of the execution plan corresponding to the card will be changed to Not published.
  • After a card is removed, the tasks associated with the card cannot be executed. The execution can be resumed only after the card is published again.
  • File Management and Script Management are default functions and cannot be removed.
Common
By default, the File Management and Script Management cards are displayed under the Common tab. Add cards as required. You can use a card to quickly create a task, add a card to favorites, or remove a card. For details, see Managing Scripts and Managing Files.
Cloud Services
Cloud Services lists the tool cards that have been released for starting and stopping ECSs, restarting RDS DB instances, changing ECS non-administrator passwords, and restarting CCE workloads. You can use a card to quickly create a task, add a card to favorites, or remove a card. For details, see Starting an ECS, Stopping an ECS, Restarting an RDS DB Instance, Changing an ECS Non-Administrator Password, and Restarting a CCE Workload.
Software Deployment
By default, there is no card under the Software Deployment tab. Add cards as required. You can use a card to quickly create a task, add a card to favorites, or remove a card.
Troubleshooting
By default, the Clearing Disk Space is displayed under the Troubleshooting tab. Add cards as required. You can use a card to quickly create a task, add a card to favorites, or remove a card. For details, see Clearing Disk Space.
Routine Inspection
By default, there is no card under the Routine Inspection tab. Add cards as required. You can use a card to quickly create a task, add a card to favorites, or remove a card.
