Managing Access Credentials
For Automation, to obtain packages from OBS, obtain an access credential first. Each user can create only one credential.
Creating a Credential
- Log in to the AOM 2.0 console.
- In the navigation pane, choose Automation (Retiring). The Automation page is displayed.
- In the navigation pane, choose Settings > Access Credentials.
- Click Authorize.
Figure 1 Access credential
- On the Create Credential page that is displayed, set the parameters listed in the following table.
Table 1 Creating a credential Parameter
Account
Account name corresponding to the credential. Enter up to 64 characters.
AK
Access key ID.
SK
Secret access key.
Description of the credential.
- Click OK.
More Operations
After creating a credential, you can view the credential information on the credential list page and perform operations listed in Table 2.
Operation |
Description |
Modifying a credential |
Click Modify in the Operation column. |
Deleting a credential |
Click Delete in the Operation column. After the credential is deleted, it will not be displayed. You can create another credential instead. For details, see Creating a Credential. |
