On this page
Configuring Parameters
Updated on 2025-03-03 GMT+08:00
The Parameters page displays all existing parameters. You can create, modify, or delete parameters on this page. When changing an ECS non-administrator password and creating a job, you can use created parameters to quickly set user password and global parameters. You can create up to 25 parameters.
Creating a Parameter
  1. Log in to the AOM 2.0 console.
  2. In the navigation pane, choose Automation (Retiring). The Automation page is displayed.
  3. In the navigation pane, choose Parameters and click Create Parameter in the upper right corner.
  4. Set parameters by referring to Table 1.
    Figure 1 Setting parameters
    Table 1 Parameters
    Parameter Type
    Type of a parameter, which can only be String.
    Parameter Name
    Name of a parameter.
    Enter up to 64 characters. Only letters are allowed.
    Encrypt
    By default, this option is disabled. Encryption is not supported at present.
    Initial Value
    Initial parameter value. Enter up to 1000 characters.
    Mandatory
    Specifies whether the parameter is mandatory when it is referenced. By default, this option is enabled.
    Input Prompt
    Message displayed when the parameter is referenced. Enter up to 1000 characters.
    Parameter description. Enter up to 1000 characters.
  5. Click Save.
More Operations
After a parameter is created, you can view the name, type, and creator of the parameter on the parameter list page. You can also perform the operations listed in Table 2.
Table 2 Related operations
Operation
Modifying a parameter
Click Modify in the Operation column.
Deleting a parameter
Click Delete in the Operation column.
