Managing Tasks
The Tasks page displays the execution records of all tasks. You can execute a created task on this page.
Supported Operations
- Log in to the AOM 2.0 console.
- In the navigation pane, choose Automation (Retiring). The Automation page is displayed.
- In the navigation pane, choose Scheduled O&M and click Create Scheduled Task in the upper right corner to create a task.
- View the task name, type, status, and duration on the task list page. You can also perform the operations listed in Table 1.
Table 1 Supported operations Operation
Viewing the task execution status
Click the name of an executed task to view the details, including the execution log, executor, and task content.
- By default, execution records of the last seven days are displayed. You can select Last 1 day, Last 1 week, Last 30 days, or Custom from the time drop-down list in the upper right corner.
By default, the update time is not displayed in the list. You can click
in the upper right corner of the list and select Updated from the drop-down list to view the update time. - The system stores execution records for up to one year.
- The custom time range can be 30 days at most.
Executing a task
- Click Execute in the Operation column of a task that has never been executed.
- Click Re-execute in the Operation column of a task that has ever been executed.
Deleting a task
Click Delete in the Operation column to delete a task.
Delete is displayed in the Operation column only when tasks have never been executed.
Searching for a task
You can search for a task by enterprise project, task name, executor, task type, or task status. Enter a keyword in the search box in the upper right corner and click
.Hiding/Showing columns in the task list
Click
and select or deselect columns to display.Refreshing the task list
Click
to refresh the task list. - By default, execution records of the last seven days are displayed. You can select Last 1 day, Last 1 week, Last 30 days, or Custom from the time drop-down list in the upper right corner.
