On this page
Starting an ECS
Updated on 2024-05-27 GMT+08:00
You can use the Starting an ECS Instance card to create a task to start one or more ECSs.
Creating a Task for Starting an ECS
  1. Log in to the AOM 2.0 console.
  2. In the navigation pane, choose Automation (Retiring). The Automation page is displayed.
  3. In the navigation pane, choose Scenarios. On the displayed page, click the Starting an ECS Instance card, or choose > Create Task in the upper right corner of the card.
  4. Set parameters by referring to Table 1.
    Figure 1 Starting an ECS
    Table 1 Parameters for starting an ECS
    Task Name
    User-defined task name.
    Enter up to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. By default, Auto is selected, which means that the system automatically generates a task name.
    Enterprise Project
    Select the enterprise project to which the task belongs.
  5. Select an instance.
    1. Click Add. The instance selection page is displayed. A maximum of 100 instances can be selected for a single task.
    2. For Instance Type, the default value is ECS. For Method, the default value is Specific. For details about the methods, see Table 2.
      Figure 2 Selecting an instance
      Table 2 Selection method description
      Selection Method
      Specific
      Enter search criteria and select instances from the instance list. By default, instances are searched by name.
      By filter
      • Enter filter attributes and values to search for instances.
      • If there are multiple filter criteria, the search is performed based on the AND relationship.
      • This method also takes effect for instances added later.
      By tag
      • Set tag keys and values, and specify one or more tags to select instances.
      • If there are multiple tags, the search is performed based on the AND relationship.
      From CMDB
      Enter search criteria or keywords and select instances from CMDB. There are two types of nodes:
      • Static: Select an ECS under a specified CMDB application.
      • Dynamic: Select a node in the CMDB application to dynamically obtain ECSs under the node. This method also takes effect for instances added later.
  6. If needed, expand More to set the review configuration and execution policy by referring to Table 3.
    Table 3 More settings
    Category
    Review
    Review
    Specifies whether to enable manual review. By default, this function is disabled.
    You can only modify the review configuration by modifying the atomic service card in the tool market.
    Reviewer
    After manual review is enabled, you need to select a reviewer.
    Alternatively, create a topic and add a subscription on the SMN console to notify a reviewer.
    Execution Policy
    Batch Release
    Specifies whether to enable batch release. By default, this function is disabled.
    Instances for Each Batch
    Number of instances on which tasks can be executed at the same time.
    Interval
    Interval for executing each batch of tasks.
  7. Click Execute. On the task execution page that is displayed, view the task execution status.
    You can also click Save. The created task is displayed on the task management page for subsequent task execution or other operations.
