- What's New
- Function Overview
- Service Overview (2.0)
- Billing (2.0)
- Getting Started (2.0)
User Guide (2.0)
- Using IAM to Grant Access to AOM
Connecting to AOM
- Connecting to AOM
- Managing Collector Base UniAgent
- Connecting Businesses to AOM
- Connecting Applications to AOM
Connecting Middleware and Custom Plug-ins to AOM
- Overview About Middleware and Custom Plug-in Connection to AOM
Connecting Middleware to AOM
- Ingesting MySQL Metrics to AOM
- Ingesting Redis Metrics to AOM
- Ingesting Kafka Metrics to AOM
- Ingesting Nginx Metrics to AOM
- Ingesting MongoDB Metrics to AOM
- Ingesting Consul Metrics to AOM
- Ingesting HAProxy Metrics to AOM
- Ingesting PostgreSQL Metrics to AOM
- Ingesting Elasticsearch Metrics to AOM
- Ingesting RabbitMQ Metrics to AOM
- Ingesting Other Middleware Metrics to AOM
- Connecting Custom Plug-ins to AOM
- Managing Middleware and Custom Plug-in Collection Tasks
- Connecting Running Environments to AOM
- Connecting Cloud Services to AOM
- Connecting Open-Source System to AOM
- Managing Log Ingestion
(New) Connecting to AOM
- AOM Access Overview
- Connecting Components to AOM
- Overview About Middleware Connection to AOM
- Managing Middleware Collection Tasks
- Ingesting Data to AOM Using Open-Source APIs and Protocols
- Managing Metric and Log Ingestion
- Observability Metric Browsing
- Dashboard Monitoring
- Alarm Monitoring
- (New) Log Management
- Log Management (Old)
Prometheus Monitoring
- Prometheus Monitoring Overview
- Managing Prometheus Instances
- Managing Prometheus Instance Metrics
- Using Prometheus Monitoring to Monitor CCE Cluster Metrics
- Configuring Multi-Account Aggregation for Unified Monitoring
- Configuring Metric Collection Rules for CCE Clusters
- Configuring Recording Rules to Improve Metric Query Efficiency
- Configuring Data Multi-Write to Dump Metrics to Self-Built Prometheus Instances
- Setting Metric Storage Duration
- Monitoring Prometheus Instance Metrics Through Dashboards
- Configuring the Remote Read Address to Enable Self-built Prometheus to Read Data from AOM
- Configuring the Remote Write Address to Report Self-Built Prometheus Data to AOM
- Checking Prometheus Instance Data Through Grafana
- Checking the Number of Metric Samples Reported by Prometheus Instances
- Infrastructure Monitoring
- Intelligent Insights (Beta)
- Application Insights
- O&M Management
- Global Settings
- Querying AOM Traces
- Migrating Data from AOM 1.0 to AOM 2.0
Best Practices (2.0)
- AOM Best Practices
- Building a Comprehensive Metric System
- Alarm Noise Reduction
- Unified Metric Monitoring
- Customizing OS Images to Automatically Connect UniAgent
- Connecting Self-Built Middleware in the CCE Container Scenario
- Interconnecting Third-Party/IDC/Huawei Cloud Cross-Region Self-Built Prometheus with AOM Prometheus Instances
FAQs (2.0)
- Dashboard
- Alarm Management
- Log Analysis
- Application Monitoring
Collection Management
- Are ICAgent and UniAgent the Same?
- What Can I Do If an ICAgent Is Offline?
- Why Is an Installed ICAgent Displayed as "Abnormal" on the UniAgent Installation and Configuration Page?
- Why Can't I View the ICAgent Status After It Is Installed?
- Why Can't AOM Monitor CPU and Memory Usage After ICAgent Is Installed?
- How Do I Obtain an AK/SK?
- FAQs About UniAgent and ICAgent Installation
- How Do I Enable the Nginx stub_status Module?
- Why Does APM Metric Collection Fail?
- Why Cannot the Installation Script Be Downloaded When I Try to Install UniAgent on an ECS?
- CMDB (Unavailable Soon)
O&M Management (Unavailable Soon)
- How Can I Obtain the OBS Permission for Installing Packages?
- Why Can't Scheduled Tasks Be Triggered?
- Can I Specify Script Parameters and Hosts During Job Execution?
- Why Is a Parameter Error Displayed When I Create a Scheduled Task Using a Cron Expression?
- How Can I Set a Review for an Execution Plan?
- Why Is "delete success:{}" Displayed (Files Cannot Be Deleted) During Disk Clearance?
- What Can I Do If the Execution Plan Is Not Updated After I Modify the Job?
- What Can I Do If "agent not found" Is Displayed?
- Why Are the Hosts Listed in Execution Logs Inconsistent with Those I Configured for a Task?
- Why Did a Task Fail to Execute?
- Other FAQs
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
- Querying the Event Alarm Rule List
- Adding an Event Alarm Rule
- Modifying an Event Alarm Rule
- Deleting an Event Alarm Rule
- Querying Events and Alarms
- Counting Events and Alarms
- Reporting Events and Alarms
- Obtaining the Alarm Sending Result
- Deleting a Silence Rule
- Adding a Silence Rule
- Modifying a Silence Rule
- Obtaining the Silence Rule List
- Querying an Alarm Action Rule Based on Rule Name
- Adding an Alarm Action Rule
- Deleting an Alarm Action Rule
- Modifying an Alarm Action Rule
- Querying the Alarm Action Rule List
- Querying Metric or Event Alarm Rules
- Adding or Modifying Metric or Event Alarm Rules
- Deleting Metric or Event Alarm Rules
Monitoring
- Querying Time Series Objects
- Querying Time Series Data
- Querying Metrics
- Querying Monitoring Data
- Adding Monitoring Data
- Adding or Modifying One or More Service Discovery Rules
- Deleting a Service Discovery Rule
- Querying Existing Service Discovery Rules
- Adding a Threshold Rule
- Querying the Threshold Rule List
- Modifying a Threshold Rule
- Deleting a Threshold Rule
- Querying a Threshold Rule
- Deleting Threshold Rules in Batches
- Querying Expression Calculation Results in a Specified Period Using the GET Method
- (Recommended) Querying Expression Calculation Results in a Specified Period Using the POST Method
- Querying the Expression Calculation Result at a Specified Time Point Using the GET Method
- (Recommended) Querying Expression Calculation Results at a Specified Time Point Using the POST Method
- Querying Tag Values
- Obtaining the Tag Name List Using the GET Method
- (Recommended) Obtaining the Tag Name List Using the POST Method
- Querying Metadata
- Log
- Prometheus Instance
- Configuration Management
CMDB (AOM 2.0)
- Creating an Application
- Deleting an Application
- Querying the Details of an Application
- Modifying an Application
- Adding a Component
- Deleting a Component
- Querying the Details of a Component
- Modifying a Component
- Creating an Environment
- Deleting an Environment
- Querying the Details of an Environment
- Modifying an Environment
- Querying the Resource List of a Node
- Querying the Details of an Application Based on the Application Name
- Querying the Details of an Environment Based on the Environment Name
- Querying the Details of a Component Based on the Component Name
- Adding a Sub-application
- Deleting a Sub-application
- Modifying a Sub-application
Automation (AOM 2.0)
- Creating a Task
- Updating a Task
- Operating a Paused Task
- Obtaining the Execution Details of a Workflow
- Terminating a Task
- Querying a Script
- Querying the Script Version
- Performing Fuzzy Search on the Job Management Page
- Querying Execution Plans (Custom Templates) Based on Job ID
- Querying the Details of an Execution Plan
- Querying Tasks
- Querying the Execution History of a Task
- Executing a Workflow
Alarm
- Historical APIs
- Examples
- Appendix
- SDK Reference
Service Overview (1.0)
- What Is AOM?
- Product Architecture
- Functions
- Application Scenarios
- Edition Differences
Metric Overview
- Introduction
- Network Metrics and Dimensions
- Disk Metrics and Dimensions
- Disk Partition Metrics
- File System Metrics and Dimensions
- Host Metrics and Dimensions
- Cluster Metrics and Dimensions
- Container Metrics and Dimensions
- VM Metrics and Dimensions
- Instance Metrics and Dimensions
- Service Metrics and Dimensions
- Security
- Restrictions
- Privacy and Sensitive Information Protection Statement
- Relationships Between AOM and Other Services
- Basic Concepts
- Permissions
- Billing
- Change History
- Getting Started (1.0)
User Guide (1.0)
- Overview
- Subscribing to AOM
- Permissions Management
- Connecting Resources to AOM
- Monitoring Overview
- Alarm Management
- Resource Monitoring
- Log Management
- Resource Groups
- Auditing
- Upgrading to AOM 2.0
- Best Practices (1.0)
FAQs (1.0)
- User FAQs
Consultation FAQs
- What Is the Billing Policy of AOM?
- What Are the Usage Restrictions of AOM?
- What Are the Differences Between AOM and APM?
- How Do I Distinguish Alarms from Events?
- What Is the Relationship Between the Time Range and Statistical Cycle?
- Does AOM Display Logs in Real Time?
- Will Container Logs Be Deleted After They Are Dumped?
- How Can I Do If I Cannot Receive Any Email Notification After Configuring a Threshold Rule?
- Why Are Connection Channels Required?
Usage FAQs
- What Can I Do If I Do Not Have the Permission to Access SMN?
- What Can I Do If Resources Are Not Running Properly?
- How Do I Set the Full-Screen Online Duration?
- What Can I Do If the Log Usage Reaches 90% or Is Full?
- How Can I Check Whether a Service Is Available?
- Why Is the Status of an Alarm Rule Displayed as "Insufficient"?
- Why the Status of a Workload that Runs Normally Is Displayed as "Abnormal" on the AOM Page?
- How Do I Create the apm_admin_trust Agency?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Is the Billing Policy of Logs?
- Why Can't I See Any Logs on the Console?
- Why Can't the Host Be Monitored After ICAgent Is Installed?
- Why Is "no crontab for root" Displayed During ICAgent Installation?
- Why Can't I Select an OBS Bucket When Configuring Log Dumping on AOM?
- Why Can't Grafana Display Content?
- Videos
More Documents
User Guide (1.0) (Kuala Lumpur Region)
Service Overview
- What Is AOM?
- Functions
Metric Overview
- Introduction
- Restrictions
- Basic Concepts
- Permissions
- Getting Started
- Alarm Management
- Log Management
- Auditing
- User FAQs
Consultation FAQs
Usage FAQs
- Change History
Service Overview
User Guide (2.0) (Kuala Lumpur Region)
- Getting Started
- Introduction
- Access Center
- Dashboard
- Alarm Management
Metric Analysis
- Metric Browsing
- Resource Usage Statistics
- Log Analysis (Beta)
- Container Insights
- Process Monitoring
- Collection Management
- Remarks
- Auditing
- Overview
- Dashboard
- Alarm Management
- Log Analysis
- Why Is an Installed ICAgent Displayed as "Abnormal" on the Agent Management Page?
- FAQs About ICAgent Installation
- Other FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
Monitoring
- Querying Metrics
- Log
Alarm
- Examples
- Appendix
- Change History
- Getting Started
- User Guide
- Obtaining an AK/SK
- How Can I Do If I Do Not Have the Permission to Access SMN?
- How Do I Distinguish Alarms and Events?
- Why the Status of a Workload that Runs Normally Is Abnormal on the AOM Page?
API Reference(ME-Abu Dhabi Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Adding or Modifying One or More Application Discovery Rules
- Deleting an Application Discovery Rule
- Querying Application Discovery Rules
- Auto Scaling
- Log
Monitoring (v1)
- Appendix
User Guide (Ankara Region)
- Getting Started
- User Guide
- Why Is the Application Status Normal but the Component Status Abnormal?
- Best Practices
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Monitoring (v2)
- Auto Scaling
- Log
- Events/Alarms
- Agent
- Application Discovery Rules
- Querying Metadata
- Querying the Calculation Results of a PromQL Expression in a Specified Period Based on Prometheus Instance
- Querying the Calculation Result of a PromQL Expression at a Specified Time Point Based on Prometheus Instance
- Querying the Values of a Tag Based on Prometheus Instance
- Obtaining the Tag Name List Based on Prometheus Instance
- Querying Metadata Based on Prometheus Instance
Monitoring (v1)
- Appendix
- Change History
Show all
O&M Management Overview
Automation depends on Huawei Cloud UniAgent capabilities. It supports atomic operations such as batch script execution, file distribution, and cloud service change. It allows you to orchestrate atomic operations, and assemble them into jobs and form standard O&M processes. Automation accumulates routine O&M operations and releases them as services for standardized, automatic, and non-differentiated O&M. It frees O&M personnel from repeated and complex application change operations, improves O&M quality and efficiency, and helps enterprises transform O&M to improve value.
To use Automation, enable this function in Menu Settings. For details, see Configuring AOM Menus.
Function description
Category |
Description |
Scenarios |
Different types of tasks are provided, and cards of different atomic service scenarios can be managed. |
Scheduled O&M |
AOM provides functions such as creating scheduled tasks, and displays execution records of scheduled tasks. |
Tasks |
AOM provides functions such as task execution, and displays the execution records of all tasks. |
Parameters |
AOM provides functions such as creating parameters, and displays all existing parameter information. |
Jobs |
AOM provides functions such as job creation and management. |
Scripts |
AOM provides functions such as creating scripts and managing script versions. |
Packages |
AOM provides functions such as creating packages and managing package versions. |
Settings |
AOM manages accounts, access credentials, and scenarios by category. |
Tool market |
AOM provides different atomic service scenarios, and allows you to bring service scenario cards online or offline. |
