Resource Management
Resource management centrally manages all your cloud services. You can view the association relationships between global cloud service resource objects and applications, including cloud resources that have not been bound to applications, facilitating resource analysis and management.
Currently, the following types of resources can be managed:
Elastic Cloud Server (ECS), databases (Relational Database Service (RDS), Data Replication Service (DRS), GaussDB NoSQL, and GaussDB), networking (Virtual Private Cloud (VPC), Elastic Load Balance (ELB), Elastic IP (EIP)), application middleware (Distributed Cache Service (DCS) and Distributed Message Service (DMS) (Kafka and RabbitMQ)), storage (Object Storage Service (OBS), Elastic Volume Service (EVS), and Cloud Backup and Recovery (CBR)), FunctionGraph)
Viewing Resource Information
- Log in to the AOM 2.0 console.
- In the navigation pane, choose Application Insights (Retiring) > CMDB.
- Select an enterprise project.
- In the navigation pane, choose Resource Management. Click a resource tab to view the names, projects, and environments of the resource's instances.
- Set filter criteria above the resource list to filter resources.
- Click
in the upper right corner to obtain the latest information about resource instances in real time. - Click
in the upper right corner and select or deselect columns to display. - Click the resource name/ID to go to the resource details page. On the resource details page, click More to go to the service console and view more information.
- After you purchase a service resource, CMDB detects and obtains the resource information in real time and displays it on the Resource Management page.
- For details about different types of resources, see Table 1.
Table 1 Resource types Resource Type
Sub-type
Information
Operation
ECS
Name/ID, private IP address, EIP, host name, AZ, region, enterprise project, application environment, UniAgent status, resource status, image name, and VPC name.
- Click a resource name in the Name/ID column. The host details page is displayed.
- Click an environment in the Application Environment column. The corresponding resource page under Application Management is displayed.
Database
RDS
Instance name/ID, instance type, DB engine version, resource status, private IP address, enterprise project, region, and application environment.
- Click an ID in the Instance Name/ID column. The RDS DB instance details page is displayed.
Database
DRS
Real-time synchronization task
Name/ID, resource status, instance type, region, enterprise project, and application environment.
- Click an ID in the Name/ID column. The DRS instance details page is displayed.
Real-time migration task
Real-time disaster recovery task
Data subscription task
Backup migration task
Database
GaussDB NoSQL
Name/ID, instance type, enterprise project, region, and application environment.
- Click an ID in the Name/ID column. The GaussDB NoSQL instance details page is displayed.
Database
Name/ID, resource status, type, enterprise project, region, and application environment.
- Click an ID in the Name/ID column. The GaussDB instance details page is displayed.
VPC
Name/ID, IPv4 network segment, status, region, enterprise project, and tag.
Click an ID in the Name/ID column. The VPC instance details page is displayed.
ELB
Name/ID, resource status, IP address and network, listener, region, enterprise project, and application environment.
- Click an ID in the Name/ID column. The load balancer details page is displayed.
- Click an environment in the Listener column. The listener details page is displayed.
EIP
EIP/ID, status, bandwidth, bandwidth details, bound instance, region, enterprise project, and associated application environment.
- Click an ID in the Name/ID column. The EIP details page is displayed.
- Click an instance name in the Bound Instance column. The host details page is displayed, including the attributes and associated cloud services.
Application middleware
DCS
Name/ID, resource status, cache type, instance type, specifications (GB), IP address, region, enterprise project, and application environment.
- Click an ID in the Name/ID column. The DCS instance details page is displayed.
DMS
Kafka
Name/ID, specifications, maximum partitions, region, enterprise project, and application environment.
- Click an ID in the Name/ID column. The CBR instance details page is displayed.
RabbitMQ
Name/ID, specifications, region, enterprise project, and application environment.
- Click an ID in the Name/ID column. The RabbitMQ instance details page is displayed.
OBS
Bucket name, region, enterprise project, and application environment.
- Click a bucket name in the Bucket Name column. The OBS instance details page is displayed.
CBR
Name/ID, resource status, resource type, billing mode, region, enterprise project, and application environment.
EVS
Name/ID, status, disk specifications, disk attributes, region, and enterprise project.
- Click an ID in the Name/ID column. The EVS instance details page is displayed.
Function
Name/ID, type, region, enterprise project, and application environment.
- Click an ID in the Name/ID column. The instance details page is displayed.
