On this page
Adding a Node
Updated on 2024-03-13 GMT+08:00
After an application is created, you can add nodes (such as components and sub-applications) to the application.
Adding a Node
  1. Log in to the AOM 2.0 console.
  2. In the navigation pane, choose Application Insights (Retiring) > CMDB.
  3. Select an enterprise project.
  4. Add a component or sub-application. Use either of the following methods:
    • After an application is created, click Add Node.
      Figure 1 Creating a sub-application
    • In the navigation pane, choose Application Management. Click next to the application in the tree on the left.
      Figure 2 Application tree
  5. Configure node information, including the node type and name.
    Figure 3 Adding a node
    Table 1 Parameters for adding a node
    Category
    Component parameters
    Component Name
    Name of a component.
    Enter 2 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
    Description of the component. Enter up to 255 characters.
    Sub-application parameters
    Unique Identifier
    Unique identifier of a sub-application.
    Sub-application Name
    Name of a sub-application.
    Description of the sub-application. Enter up to 255 characters.
    • Up to three levels of sub-applications can be created under an application.
    • Up to 50 sub-applications can be created under an application.
    • Up to 50 components can be created under an application.
  6. Click OK.
More Operations
After the node is created, you can also perform the operations listed in Table 2.
Table 2 Related operations
Operation
Adding a sub-node
Locate the target node and click to add a sub-node by referring to Adding a Node.
Modifying a node
Locate the target node and choose > Modify.
Deleting a node
Locate the target node and choose > Delete.
Transferring a node
Locate the target node and choose > Transfer. On the page that is displayed, select the target node to transfer.
Adding an environment
Locate the target sub-node and click to add an environment by referring to Adding an Environment.
Viewing node information
Locate a sub-application or component and click Sub-application Info or Component Info in the right pane.
