Help Center/ Application Operations Management/ User Guide/ Prometheus Monitoring/ Configuring Data Multi-Write to Dump Metrics to Self-Built Prometheus Instances
Updated on 2026-09-18 GMT+08:00
This function enables cross-VPC access without exposing server network information. Monitoring data can be reported to self-built Prometheus instances more securely.
  • Only the common Prometheus instance and the Prometheus instances for CCE support data multi-write. Currently, the data multi-write function is not generally available. If you need this function, submit a service ticket. Note that only some regions support this function.
  • Metrics generated based on pre-aggregation rules do not support data multi-write.
  • Some default metrics generated by AOM (such as aom_metrics_total, aom_metrics_total_per_hour, ALERTS, and ALERTS_FOR_STATE) do not support data multi-write.
  • When the metrics of the default Prometheus instance are dumped using the data multi-write function, the names of some dumped metrics may be inconsistent with those displayed on the AOM page. For example, the names of metrics reported by ICAgent are in lower camel case. These names are converted to the snake case when being displayed on the AOM page. (Example: memUsage is displayed as aom_container_memory_usage.)
  • If IAM users need to use the data multi-write function, obtain the AOMFullAccessPolicy, VPCEndpoint ReadOnlyAccess, and VPC ReadOnlyAccess permissions in advance.
  • In high-concurrency or network retry scenarios, when multiple data sources concurrently send metric Prometheus Remote Write, data timestamps may be interleaved (out of order). If out-of-order write is not enabled for the self-managed Prometheus, the system will reject the write and throw an "out of order sample" error. As a result, some service metrics will be lost. You are advised to set the out_of_order_time_window parameter to a proper non-zero value (for example, 5m) in the configuration file of the self-built Prometheus to enable the out-of-order write window.
  1. Log in to the AOM 2.0 console.
  2. In the navigation pane on the left, choose Prometheus Monitoring > Instances.
  3. In the Prometheus instance list, click a Prometheus instance that supports data multi-write. The instance details page is displayed.
  4. In the navigation pane, choose Data Write.
  5. Configure the intranet.
    1. Select a VPC endpoint service. Select a VPC endpoint service from the drop-down list.
      • The selected VPC endpoint service must be in the same VPC as the self-built Prometheus instance. Only VPC endpoint services whose Backend Resource Type is Cloud Server or Elastic Load Balance can be selected.
    2. Add whitelist permissions.
      Click Add Now to add the provided account ID to the VPC endpoint service whitelist.
    3. Create a VPC endpoint.
      Click Create VPC Endpoint.
  6. On the VPC endpoint service details page, go to the Connection Management tab page and ensure that the status is Accepted.
  7. Set a data write address. Table 1 describes the parameters.
    Table 1 Data write address parameters
    Self-built Prometheus Instance's Remote Write Address
    Remote write address of the self-built Prometheus instance. Set this parameter based on site requirements.
    The format is "{IP address:port number}/{path}". Example: 192.168.0.1:9090/api/v1/write
    Authentication Mode
    Authentication mode for accessing a self-built Prometheus instance.
    • Basic: Enter the username and password of the self-built Prometheus instance.
    • Token: A token is required for authentication.
    • None: No authentication is required.
  8. Click Save.
    Wait for about 5 minutes. You can check the reported metric data in the self-built Prometheus instance.
