Viewing a Public IP Address
This topic describes how to view a public IP address.
- After you purchase a public IP address, Anti-DDoS automatically enables the protection by default, and protects your public IP address against DDoS attacks.
- You are not allowed to disable Anti-DDoS after it has been enabled.
- You have obtained a username and password for logging in to the management console.
- You have purchased at least one public IP address.
- Click
in the upper left corner of the management console and select the region and project. - Click
in the upper left corner of the page and choose Security & Compliance > Anti-DDoS.
Figure 1 Anti-DDoS
- On the Public IP Addresses tab, view all protected public IP addresses. Table 1 describes the parameters.
Figure 2 Viewing a public IP address
- Click Enable Anti-DDoS for All IP Addresses to enable the protection for all unprotected IP addresses in the current region.
- After the default Anti-DDoS protection settings are enabled, traffic is scrubbed when its volume reaches 120 Mbit/s. You can modify Anti-DDoS protection settings according to Configuring an Anti-DDoS Protection Policy.
- Anti-DDoS provides a 500 Mbit/s mitigation capacity against DDoS attacks. Traffic that exceeds 500 Mbit/s from the attacked public IP address will be routed to the black hole and the legitimate traffic will be discarded. Therefore if you may suffer from volumetric attacks exceeding 500 Mbit/s, it is a better choice to purchase HUAWEI CLOUD Advanced Anti-DDoS (AAD) for enhanced protection.
- The All statuses drop-down box enables you to specify a status so that only public IP addresses of the selected status are displayed.
- Enter a public IP address or a keyword of a public IP address in the search box and click
or
to search for the desired public IP address.
Table 1 Parameter description Parameter
Public IP Address
Public IP address protected by Anti-DDoS
NOTE:If Anti-DDoS is enabled for a public IP address, you can click the IP address to go to its Monitoring Report page.
Protection Status
Protection status of a public IP address. The values are:
- Normal
- Configuring
- Disabled
- Cleaning
- Black hole
