- What's New
- Getting Started
User Guide
- Management Platform
- Developer Center
Developer Guide
Product Development
- Obtaining Development Resources
- Creating a Project and Product
- Developing a Product Model
Developing a Codec
- Development Guide
- Offline Development
- Codec Development Examples
Reference
- Message Processing Flow
- decode API Description
- Description of encode API
- getManufacturerId Interface Description
- getModel Interface Description
- Precautions on Interface Implementation
- Input/Output Format of the Codec Plug-In
- Implementation Sample Interpretation
- Appendix: Encryption Algorithms Supported by the JDK
- Developing an Application
- Developing a Device
- Self-Service Testing
- Product Release
- Device Interconnection
- Application Interconnection
SDK Usage Guide on the Device Side
LiteOS SDK Integration Development Guide
- Overview
Processfor Connecting Devices to OceanConnect on the Device Side
- Preparations
- Entrypoint Function for LiteOS SDK Device-Cloud Interconnect Components
- Initializing LiteOS SDK Device-Cloud Interconnect Components
- Creating a Data Reporting Task
- Command Processing Function for LiteOS SDK Device-Cloud Interconnect Components
- Main Function Body for LiteOS SDK Device-Cloud Interconnect Components
- Data Structure
- Appendix 1 LWM2M
SDK Usage Guide on the Application Side
Huawei IoT Platform Java SDK Usage Guide
- Before You Start
- Requirements for the Development Environment
- Downloading Related Development Resources
- Importing the Java SDK Demo
- Initializing and Configuring Certificates
- Calling Service APIs
- Implementing Callback APIs and Making, Exporting, and Uploading a Callback Certificate
- Service API Calling Process and Precautions
- Testing the SDK
Product Development
API Reference
Northbound API Reference
- Overview
- API Usage Statement
- Secure Application Access
- Device Management
- Data Collection
Subscription Management
- Subscribing to Service Data of the IoT Platform
- Subscribing to Management Data of the IoT Platform
- Querying a Subscription
- Querying Subscription in Batches
- Deleting a Subscription
- Deleting Subscriptions in Batches
Push Notification
- Pushing Device Registration Notifications
- Pushing Device Binding Notifications
- Pushing Device Information Change Notifications
- Pushing Device Data Change Notifications
- Pushing Batch Device Data Change Notifications
- Pushing Device Service Capability Change Notifications
- Pushing Device Service Capability Addition Notifications
- Pushing Device Service Capability Deletion Notifications
- Pushing Device Deletion Notifications
- Pushing Device Acknowledgment Notifications
- Pushing Device Command Response Notifications
- Pushing Command Status Change Notifications
- Pushing Rule Event Notifications
- Pushing Device Shadow Status Change Notifications
- Pushing Software Upgrade Status Change Notifications
- Pushing Software Upgrade Result Notifications
- Pushing Firmware Upgrade Status Change Notifications
- Pushing Firmware Upgrade Result Notifications
- Command Delivery
- Batch Processing
- Device Group Management
- Device Upgrade
Northbound Java SDK API Reference
- SDK Demo Architecture and Usage Guide
- SDK Initialization Configuration and Test
Service API List
- Device Management
- Batch Processing
- Subscription Management
Message Push
- Pushing Device Service Information Change Notifications
- Pushing Device Event Notifications
- Pushing Device Model Addition Notifications
- Pushing Device Model Deletion Notifications
- Pushing NB-IoT Command Status Change Notifications
- Command Delivery (NB-IoT Commands)
- Command Delivery (Non-NB-IoT Commands)
- Data Collection
Device Upgrade
- Querying a Version Package List
- Querying a Specified Version Package
- Deleting a Specified Version Package
- Creating a Software Upgrade Task
- Creating a Firmware Upgrade Task
- Querying the Result of a Specified Upgrade Task
- Querying Details About Subtasks of a Specified Upgrade Task
- Querying an Upgrade Task List
Northbound PHP SDK API Reference
Service API List
- Device Management
- Batch Processing
Message Push
- NB-IoT Device Command Status Change Notification
- Data Collection
Device Upgrade
Northbound Python SDK API Reference
Service API List
- Device Management
- Batch Processing
Message Push
- Data Collection
Device Upgrade
- AgentLite API Reference (Android)
AgentLite API Reference (C)
- Before You Start
- API Description
Common Data Structures
- ST_IOTA_DEVICE_INFO Structure
- IEs in EN_IOTA_BIND_IE_TYPE Messages
- Enumerated Values of the EN_IOTA_BIND_RESULT_TYPE Parameter
- IEs in EN_IOTA_LGN_IE_TYPE Messages
- Enumerated Values of the EN_IOTA_LGN_REASON_TYPE Parameter
- Enumerated Values of the EN_IOTA_CFG_TYPE Parameter
- IEs in EN_IOTA_HUB_IE_TYPE Messages
- Enumerated Values of the EN_IOTA_HUB_RESULT_TYPE Parameter
- IEs in EN_IOTA_DATATRANS_IE_TYPE Messages
- IEs in EN_IOTA_DEVUPDATE_IE_TYPE Messages
- Data Types
- AgentLite API Reference (Java)
- MQTT Interface Reference
- FAQs
- Specifications
- Product Use
Secondary Development
FAQs About Product Development
Profile Definition
- How to Develop a Profile
- Upload Is Unavailable When Uploading a Profile to the Developer Center
- Incorrect File Format Is Displayed When Uploading a Profile to the Developer Center
- Message Is Displayed Indicating That the Manufacturer ID and Device Model Exist When Uploading a Profile to the Developer Center
- How to Select a Data Type When Developing a Profile Online
- Profile Cannot Be Edited
Plug-In Development
- How to Develop Codecs
- Failed to Deploy a Plug-in That Is Developed Online
- What Is the Code Rule for Fields of the string and varstring Types
- What Is the Code Rule for Fields of the array and variant Types
- Whether Plug-Ins That Are Developed Online Support Transparent Transmission
- How to Use messageId During Online Codec Development
- How to Configure a Command Delivery Response During Online Codec Development
- Failed to Deploy a Plug-in That Is Developed Offline
- Failed to Upload a Plug-in That Is Developed Offline
- Plug-In Package Developed Offline Has Been Checked But Cannot Be Found When Uploading to the IoT Platform
- Codec Exception Occurs After a Plug-In Package Developed Offline That Has Been Checked Is Uploaded to the IoT Platform
- Offline Signature Fails
Device Development
- Registered Devices Cannot Connect to the IoT Platform
- Message 513 Is Reported When Devices Are Connected to the IoT Platform
- DTLS Encryption Algorithms Supported by the IoT Platform
- What Does CTNB Mean
- How to Select PSM, DRX, and eDRX
- Devices Cannot Receive Commands from the IoT Platform
- IoT Platform Does Not Receive Data Reported by Devices
- Historical Data Does Not Contain Data Reported By Devices While No Error Occurs
- Duration for Devices to Receive Commands
- Devices Fail to Receive Data Reporting Responses
- Data Reporting Is Successful at One Position But Fails at Another Position
- Command Status Is Not Changed to Successful After a Device Reports the Command Execution Result
- Whether the IoT Platform Can Switch Between the Big-Endian and Little-Endian
- Commands Fail to Be Delivered When a Device in DRX Mode Does Not Report Data in One to Two Days
Profile Definition
FAQs About Application Development
Calling APIs
- Authentication API of the IoT Platform Is Successfully Called Locally But Fails to Be Called on Application Servers
- Error Occurs When an NA Calls an API
- Online Application Simulator Fails to Deliver Commands
- Command Is Successfully Delivered Using the Simulator But Fails to Be Delivered by Calling the API
- Application Server Fails to Deliver Commands and Receives Error Code 403
- How Does an Application Server Deliver a Cache Command
- What Does an Expired Command Mean
- Does the IoT Platform Support Command Resending
- What Does a Timeout Command Mean
- Can the IoT Platform Deliver Commands in Batches
- Are the APIs of the IoT Platform Called Only Using Java
- What Are the Command States on the IoT Platform
- Failed to Call the Calling the Registering Directly Connected Devices API
- APIs Fail To Be Called After a Period of Time While Parameters Remain Unchanged
- Commands Fail to Be Sent After a Period of Time While the Previous Commands Are Successfully Sent
- Historical Data Is Not Returned When the Querying Historical Device Data API Is Called
- Devices Registered with the IoT Platform Are Deleted After a Period of Time
Subscription and Push
- Invalid Callback Address Occurs When Calling the Subscription API
- How to Obtain the subscriptionId When Calling the Querying Subscription in Batches API
- Application Server Fails to Receive Data Pushed by the IoT Platform
- How Do I Export the HTTPS Push Certificate
- Difference Between deviceDatachanged and deviceDataschanged
- How Does an Application Server Obtain the IMEI of Devices
- Application Server Receives Data But an Error Is Displayed on the IoT Platform
- Push Messages May Fail to Be Sent to Application Servers
- How Does an Application Servers Obtain The Address Used by the IoT Platform to Push Messages
- Does the IoT Platform Supports Re-push
- How Does an Application Server Receive a Command Status Change Notification
- Application Servers That Have Subscribed to Confirmation Notifications and Command Response Notifications Fail to Receive Push Messages
- Does the IoT Platform Support Only HTTPS Callback Addresses
- Can the IoT Platform Push Data Reported by Different Devices Under the Same Application to Two Servers
- Can a Subscription Address Be a Domain Name
- Can a Callback Address Be Changed
- How Do I Obtain the Callback URL When Calling the Subscription API
Calling APIs
FAQs About Software/Firmware Upgrade
- What Is Software/Firmware Upgrade
- Can IoT Platform Download Software/Firmware Packages From Third-party Servers
- Can the Target Version Be Earlier Than the Source Version?
- How Do I Obtain Software/Firmware Packages and Their Version Numbers
- Software/Firmware Upgrade Task Is Ended Immediately After Being Created
- What Is the Source Version Required for Uploading a Firmware Package on the Management Portal
- When Reporting Data, Devices Receive the Software/Firmware Version Query Command from the IoT Platform
- Are Services Interrupted During the Software/Firmware Upgrade
- What Are Common Software/Firmware Upgrade Errors
- Retry When Some Devices in the Group Failed to Be Upgraded
- Is Resumable Transmission Supported When the IoT Platform Sends Software/Firmware Packages to Devices
- Does the IoT Platform Support Device Registration in Batches
- Does the IoT Platform Perform Flow Control on Applications and Devices
- How Does an Application Server Obtain Data Reported by Devices to the IoT Platform
- Is the Maximum Number of Applications and Devices Restricted on the IoT Platform
- Why Is an Online Device Changed to an Abnormal or Offline State After a Period of Time
- Are Command Delivery and Data Reporting Successful After a Device Becomes Abnormal or Offline
- How Long Does a Device Receive an Immediately-Delivered Command in eDRX Mode
- How Long Is Data Stored on the IoT Platform
- Can Multiple Devices Use One IMEI
Device Management
Overview
- Add a physical device on the Device Management page. The device name is defined by the developer. When the device development is complete, developers can add physical devices on the Developer Center where developers can perform end-to-end testing on the physical devices, codecs, and NAs.
- Add a virtual device on the Device Management page. The device name is defined by the IoT platform. The name of the virtual device is in the format of Product Name+Simulator. Only one virtual device can be added for each product. When the device development is not complete, developers can create a virtual device on the Developer Center to test the codecs and NAs.
Adding a Physical Device
- Choose Products > Device Management and click Add Physical Device.
- In the Add Physical Device dialog box displayed, select a device.
- Configure device information and click Confirm.
- Device Name can contain only letters, digits, and underscores (_) and must be unique in the product.
- Node ID must be set to a unique value, such as the IMEI or MAC address of the device.
- Select Unencrypted or Encrypted based on site requirements. If this parameter is set to Unencrypted, the device uses the CoAP/UDP protocol to connect to the IoT platform. If this parameter is set to Encrypted, the device uses the CoAPS/DTLS protocol to connect to the IoT platform.
After the device is added, Device ID and PSK are returned. Keep the PSK securely as it is required when the device uses DTLS to connect to the IoT platform.
- After a physical device is added, you can view details and perform tests on the device and the application.
- In the device list, click the newly added device. On the page displayed, you can view device information, historical data, logs, and historical commands.
- In the device list, click Test Product at the row where the newly added device resides to test the product.
Connect the device to the IoT platform and report data. View the data reporting result in Application Simulator and processing logs of the IoT platform in Message Tracing.
Deliver a command in Application Simulator. View processing logs of the IoT platform in Message Tracing and check the received command on the device.
- In the device list, click Test Application at the row where the newly added device resides to test the application.
Connect the device to the IoT platform and report data. View the data reporting result in IoT Platform and Application Simulator and processing logs of the IoT platform in Message Tracing.
Connect the NA to the IoT platform and deliver a command. View the command delivery result in IoT Platform and on the device and processing logs of the IoT platform in Message Tracing.
Adding a Virtual Device
- Choose Products > Device Management and click Add Virtual Device.
- In the Add Virtual Device dialog box displayed, select a device.
- After a virtual device is added, you can view details and perform testing on the device and the application.
In Device Simulator, enter a hexadecimal code stream or JSON data (for example, enter a hexadecimal code stream) and click Send. Then, view the data reporting result in Application Simulator and processing logs of the IoT platform in Message Tracing.
Deliver a command in Application Simulator. View the received command (for example, a hexadecimal code stream) in Device Simulator and processing logs of the IoT platform in Message Tracing.
In Device Simulator, enter a hexadecimal code stream or JSON data (for example, enter a hexadecimal code stream) and click Send. Then, view the data reporting result in IoT Platform and Application Simulator and processing logs of the IoT platform in Message Tracing.
After the NA delivers a command, view the received command (for example, a hexadecimal code stream) in Device Simulator and view processing logs of the IoT platform in Message Tracing.
