What Can I Do If an Xid Error Is Displayed in the Message Log When a GPU-accelerated ECS Is Faulty?
Possible Causes
| XID | Description |
| 32 | Invalid or corrupted push buffer stream |
| 74 | NVLINK Error, which indicates that the GPU hardware is faulty and needs to be brought offline for repair. |
| 79 | GPU has fallen off the bus, which indicates that the bus is disconnected and needs to be brought offline for repair. |
For details, see https://docs.nvidia.com/deploy/xid-errors/index.html.
Solution
- Run the dmesg | grep –i xid command to check whether there are Xid errors.
- Stop the services, perform service migration, collect fault information by referring to Fault Information Collection, and contact technical support.
