Help Center/ Elastic Cloud Server/ Troubleshooting/ Self-diagnosis of Faulty GPU-accelerated ECSs/ Self-recovery from Non-hardware Faults/ How Do I Handle Driver Compatibility Issues?
Updated on 2025-12-16 GMT+08:00
Symptom
The error message "No devices were found" is displayed after you run the nvidia-smi command.
Solution
- Check the ECS specifications and image information.
- If the ECS is using NVIDIA Tesla T4 GPUs (such as the Pi2 or G6 ECS), refer to Why Is the T4 GPU Display Abnormal?
- If the ECS is using other GPUs, go to the next step.
- Check the system log /var/log/message for any reported driver-related errors.
- If the error message "Failed to copy vbios to system memory" is displayed, the possible cause may be frequent driver loading/uninstallation. You are advised to enable the driver's persistence mode to keep the driver in loading state.
- Run the following command to enable the driver's persistence mode.
- Run the following command to open and edit the /etc/rc.local file.
vim /etc/rc.local
- Configure automatic startup and write the nvidia-smi -pm 1 command to the /etc/rc.local file.
- Press Esc and enter :wq to save the settings and exit.
- Run the following command to add startup permissions.
- If no error is found, go to the next step.
- Check whether the ECS uses Tesla 510.xx.xx.
- If yes, the driver version may be incompatible with the image. You are advised to change the driver version. For details, see GPU Driver.
- If no, go to the next step.
- If the root cause fails to be identified, collect fault information by referring to Fault Information Collection and contact technical support.
Parent topic: Self-recovery from Non-hardware Faults
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
