Help Center/ Elastic Cloud Server/ Troubleshooting/ Self-diagnosis of Faulty GPU-accelerated ECSs/ Self-recovery from Non-hardware Faults/ What Do I Do If the Driver Is Unavailable After the Kernel Is Upgraded?
Updated on 2026-01-22 GMT+08:00
Symptom
- When you run the nvidia-smi command, the error message "failed to initialize NVML: Driver/library version mismatch" is displayed.
- When you run the nvidia-smi command, the error message "NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver" is displayed.
Checking the Kernel Version
- Run the following command to check the current kernel version:
- Run the corresponding command on the ECS to check the version of the kernel when the driver was installed:
- CentOS: find /usr/lib/modules -name nvidia.ko
- Ubuntu: find /lib/modules -name nvidia.ko
If the current kernel version is different from the kernel version when the driver was installed, the driver is unavailable after the kernel is upgraded.
Solution
- Run the following commands in sequence to remove the NVIDIA driver:
rmmod nvidia_modeset
rmmod nvidia
- Run the following command to query the GPU information:
- If the command output is normal, the problem has been resolved.
- If the fault persists in the command output, refer to Why Is the GPU Driver Unavailable?
Parent topic: Self-recovery from Non-hardware Faults
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
