How Do I Query XID Errors?
XID messages are errors printed by the NVIDIA driver to the OS kernel logs or event logs. These messages can be used to identify GPU error events and provide information such as the error type, error location, and error code in the GPU hardware, NVIDIA software, or your applications.
You can perform the following steps to query the XID errors:
- Log in to the ECS.
- Run the following command to check whether there are XID errors and save the command output:
- If the XID on the GPU node is empty, there is no XID error message.
- If the XID on the GPU node is not empty, refer to What Types of GPU-accelerated ECS Faults Are There? or contact technical support.
