Why Is the T4 GPU Display Abnormal?
Symptom
No devices were found
Possible Causes
NVIDIA Tesla T4 GPU is a new version of NVIDIA. By default, the GSP firmware is enabled and used. As a result, the GPU cannot be identified.
Method 1
The following settings will become invalid after the ECS is restarted.
Method 2
- Run the following command to open the /etc/modprobe.d/nvidia.conf file:
vim /etc/modprobe.d/nvidia.conf
Press i to enter the editing mode.
- Add the following information to /etc/modprobe.d/nvidia.conf:
options nvidia NVreg_EnableGpuFirmware=0
Press Esc and enter :wq! to save the modification and exit.
- Run the following command to restart the ECS:
- If the fault persists, contact customer service.
