Help Center/ Elastic Cloud Server/ Troubleshooting/ Remote Login/ Remote Login Errors on Windows/ Why Am I Seeing an Error Message That Says Identity of Remote Computer Cannot be Verified When I Log In to a Windows ECS?
Updated on 2025-12-16 GMT+08:00
Symptom
An error message is displayed indicating that the identity of the remote computer cannot be verified. You are required to enter the password and log in again.
Figure 1 Protocol error
Possible Causes
Security software installed on the ECS prevents logins from unknown IP addresses.
Solution
  • Uninstall the security software.
  • Open the security software and enable the default login mode.
