Help Center/ Elastic Cloud Server/ Troubleshooting/ Remote Login/ Remote Login Errors on Windows/ Why Does the System Display Error Code 0x112f When I Log In to a Windows ECS?
Updated on 2025-12-16 GMT+08:00
Symptom
When you log in to a Windows ECS, the system displays error code 0x112f, as shown in Figure 1.
Figure 1 Error message (code: 0x112f)
Possible Causes
The ECS memory is insufficient.
Solution
  • Method 1 (recommended)
    Modify the ECS specifications to increase the vCPUs and memory size. For details about how to modify specifications, see Modifying Individual ECS Specifications.
  • Method 2:
    Enable virtual memory on the ECS to obtain its idle memory.
    For details about how to enable virtual memory, see How Can I Enable Virtual Memory on a Windows ECS?
    This method will deteriorate the disk I/O performance, so use this method only when necessary.
