Why Is the IP Address Lost After the System Time of an ECS Is Modified?
Symptom
After the system time of an ECS is modified, its IP address is lost.
Possible Causes
The time range you modified exceeds the DHCP lease time.
The default DHCP lease time set when you create a VPC subnet is 365 days (24 hours for VPC subnets created before). If you manually change the ECS system time and the time difference between the old and new time is longer than 24 hours, the DHCP lease may be expired and the ECS IP address will be lost.
Solution
If you do need to change the ECS system time, and the time difference is longer than your DHCP lease time, change the ECS IP address obtaining mode to static before you change the ECS system time.
