What Can I Do If the Fork Process Failed and New Threads Cannot Be Created?
Symptom
The following error message is displayed during command execution or log printing on Linux ECSs.
Error message 1:
root@localhost:~# free -g total used free shared buffers cached Mem: 94 43 51 0 0 0 Swap: 19 0 19 root@localhost:~# uname -a -bash: fork: Cannot allocate memory
Error message 2:
xxxxsshd2[23985]: fatal: setresuid 20054: Resource temporarily unavailable xxxxsshd2[28377]: Disconnecting: fork failed: Resource temporarily unavailable xxxxsshd2[4484]: Disconnecting: fork failed: Resource temporarily unavailable
Error message 3:
[root@ecs-xxxx ~]$ sudo docker info runtime/cgo: pthread_create failed: Resource temporarily unavailable SIGABRT: abort
Possible Causes
Generally, the preceding errors occur because the thread fails to be created. The possible cause is that the ECS memory is insufficient and the number of current threads reaches the configured maximum value.
Solution
- Monitor the ECS memory usage using the server monitoring function. For details, see Viewing ECS Metrics.
- If the memory is insufficient, increase the memory or optimize the memory by referring to General Operations for Modifying Specifications.
- If the memory is sufficient, go to 3.
- Log in to an ECS as user root and run the following commands to check the message and dmesg logs:
dmesg -T
- Run the following command to check the total number of threads in the current system:
- Run the following commands to obtain two values and compare the values with the total number of system threads queried in 4:
sysctl -a | grep pid_max
sysctl -a | grep threads-max
- If the total number of threads in the current system is close to either of the two values, modify the values of pid_max and threads-max. For details, see Modifying the values of pid_max and threads-max.
- If they do not stay close, go to 6.
- Run the following command to determine the PID of the error process:
- Run the following command to check the limits configuration of the process based on the PID obtained in the last step:
cat /proc/pid/limits
Figure 2 Checking the limits configuration of the process- Check the value of Max processes. If the number of threads is close to the value of Max processes, modify the value of limits. For details, see Modifying the value of limits.
- If they do not stay close, go to 8.
- Run the following commands to obtain the values of pid_max and pids.current based on the log error cgroup:
cat /sys/fs/cgroup/pids/Directory where the error in the combined logs is reported/pids.max
cat /sys/fs/cgroup/pids/Directory where the error in the combined logs is reported/pids.current
Figure 3 cgroup directoryAn example is as follows:
- Run the following command to search for the cgroup directory based on the PID of the process:
cat /proc/pid/cgroup
Figure 4 Searching for the cgroup directory based on the PIDIn the command output, /user.slice/user-0.slice/session-5.scope/ in the pids line can be combined with /sys/fs/cgroup/pids/ to specify the cgroup directory /sys/fs/cgroup/pids/user.slice/user-0.slice/session-5.scope/.
- Run the following commands to obtain the values of pid_max and pids.current based on the cgroup directory:
cat /sys/fs/cgroup/pids/user.slice/user-0.slice/session-5.scope/pids.max
cat /sys/fs/cgroup/pids/user.slice/user-0.slice/session-5.scope/pids.current
- If the value of pids.current is close to that of pids.max, modify the value of cgroup. For details, see Modifying the value of cgroup.
- If they do not stay close, submit a service ticket.
Related Commands
- Modifying the values of pid_max and threads-max.
- Default parameters vary by OS version. Therefore, run the following commands to query how pid_max and threads-max is configured:
- Run the following commands to modify the values of pid_max and threads-max:
echo 'kernel.pid_max = 4194304' >> /etc/sysctl.conf
echo 'kernel.threads-max = 4194304' >> /etc/sysctl.conf
- Run the following command to make the new value be applied:
- Modifying the value of limits
- Log in to the ECS as the user who starts the error reporting process and run the following command to query the current configuration of limits:
ulimit -u
- Run the following commands to configure a proper upper limit for nproc based on service requirements and the current value:
For example, run the following commands to configure 100000 for nproc as user root:
echo 'root soft nproc 100000' >> /etc/security/limits.conf
echo 'root hard nproc 100000' >> /etc/security/limits.conf
- Log in to the ECS again and run the following command to check whether the configuration has taken effect:
- Modifying the value of cgroup
- Temporary modification solution
Run the following command to temporarily change the upper limit of the cgroup directory to the maximum value:
echo max > /sys/fs/cgroup/pids/user.slice/user-0.slice/session-25.scope/pids.max
- Permanent modification solution:
Run the following command to set the cgroup directory to infinity and modify the cgroup directory that exceeds the limit:
The value can be adjusted as required. After the modification is complete, restart the ECS for the configuration to be applied.
echo DefaultTasksMax=infinity >>/etc/systemd/system.conf
echo DefaultTasksMax=infinity >>/etc/systemd/user.conf
echo UserTasksMax=infinity >>/etc/systemd/logind.conf
