Help Center/ Elastic Cloud Server/ Troubleshooting/ Linux ECS Issues/ What Can I Do If Switching from a Non-root User to User root Times Out?
Updated on 2025-07-30 GMT+08:00
Symptom
When you run the sudo command to switch to user root on an Ubuntu or Debian ECS, the system prompts connection timeout.
Figure 1 Connection timeout
Solution
  1. Log in to the ECS.
  2. Run the following command to edit the hosts configuration file:
    vi /etc/hosts
  3. Press i to enter insert mode.
  4. Add the IP address and hostname to the last line of the hosts configuration file.
    Private IP address hostname
    An example is provided as follows:
    If the ECS hostname is hostname and the private IP address of the ECS is 192.168.0.1, add the following statement:
    192.168.0.1 hostname
  5. Press Esc to exit editing mode.
  6. Run the following command to save the configuration and exit:
    :wq
To update the hostname of an Ubuntu or Debian ECS, set the value of parameter manage_etc_hosts in the /etc/cloud/cloud.cfg file to false and update the new hostname in the /etc/hosts file. When editing the /etc/hosts file, do not delete the statement in the line where 127.0.0.1 is located. Otherwise, switching from a non-root user to user root will time out.
