Why Do I Get the Error "No space left on device" When I Create a File on a Linux ECS?
Symptom
When you create a file on a Linux ECS, the error message "No space left on device" is displayed.
Possible Causes
- The block usage on the disk reaches 100%.
 - The inode usage on the disk reaches 100%.
 - Certain disk space is not freed up because there are unreleased file handles.
 - The value of fs.inotify.max_user_watches has been reached.
100% Block Usage
Run the following command to view the disk space usage:
df -h
If information similar to the following is displayed, the blocks have been used up.
Solution: Expand the capacity of the disk.
100% Inode Usage
Run the following command to view the inode usage:
df -i
If information similar to the following is displayed, the inodes have been used up.
Space Occupied by Deleted Files
- Run the df -h command to check whether the block usage reaches 100%.
 - Run the df -i command to check whether the inode usage is relatively low, for example 1%, as shown in the following figure.
 - Run the du -sh command to view the total disk space used by files. You may notice that there is a significant difference between the usage space and available space.
Solution
Value of fs.inotify.max_user_watches Reached
If there is insufficient space for Linux ECSs, "No space left on device" will be displayed.
Solution
- Run the following command to edit the /etc/sysctl.conf file:
vi /etc/sysctl.conf
 - Add the following content to the file:
fs.inotify.max_user_watches = 524288
 - Run the following command for the modification to take effect:
inotify is used to monitor file system events. By default, a maximum of 8,192 files can be watched for each real user ID. You can run the following command to obtain the current limit:
cat /proc/sys/fs/inotify/max_user_watches
If the limit is too low to watch all files, increase the limit.
