Help Center/ Elastic Cloud Server/ Troubleshooting/ Linux ECS Issues/ How Do I Configure atop and kdump on Linux ECSs?
Updated on 2026-01-22 GMT+08:00
Introduction to atop
atop is a monitor for Linux that can report the activity of all processes and resource consumption by all processes at regular intervals. It shows system-level activity related to the CPU, memory, disks, and network layers for every process. It also logs system and process activities daily and saves the logs in disks for long-term analysis.
Preparing for atop Installation
An EIP is required and can be used to access the yum software source.
The atop tool used for node resource monitoring consumes a small number of CPU cores and memory to collect system resources and uses some disk space to record logs. The log path is /var/log/atop.
Configuring atop for CentOS 6
  1. Run the following command to install atop:
    yum install -y atop
  2. Run the following command to modify the configuration file of atop:
    vi /etc/sysconfig/atop
    Modify the following parameters, save the modification, and exit:
    Change the value of LOGINTERVAL to, for example, 15. The default value of LOGINTERVAL is 600, in seconds.
    LOGINTERVAL=15
    vi /etc/logrotate.d/atop
    You can change the value of -mtime to, for example, 3. The default retention period of atop logs is 40 days.
       postrotate
          /usr/bin/find /var/log/atop/ -maxdepth 1 -mount -name atop_\[0-9\]\[0-9\]\[0-9\]\[0-9\]\[0-9\]\[0-9\]\[0-9\]\[0-9\]\* -mtime +3 -exec /bin/rm {} \;
        endscript
  3. Run the following command to start atop:
    service atop start
  4. Run the following command to check the status of atop. is running indicates that atop is running properly.
    service atop status
    atop (pid 3170) is running
  5. Run the following command to stop atop after troubleshooting to release the system and disk resources occupied by atop:
    service atop stop
Configuring atop for CentOS 7/8, AlmaLinux, and Rocky Linux
    yum install -y atop
    • Change the value of LOGINTERVAL to, for example, 15. The default value of LOGINTERVAL is 600, in seconds.
    • Change the value of LOGGENERATIONS to, for example, 3. The default retention period of atop logs is 28 days.
    LOGINTERVAL=15
    LOGGENERATIONS=3
  1. Run the following command to start atop:
    systemctl enable --now atop atopacct atop-rotate.timer
  2. Check whether atop is started. If atop atopacct is active (running), or atop-rotate.timer is active (waiting), the service is running properly.
    systemctl status atop atopacct atop-rotate.timer
    atop.service - Atop advanced performance monitor
    Loaded: loaded (/usr/lib/systemd/system/atop.service; enabled; vendor preset: enabled)
    Active: active (running)
    atopacct.service - Atop process accounting daemon
    Loaded: loaded (/usr/lib/systemd/system/atopacct.service; enabled; vendor preset: enabled)
    atop-rotate.timer - Daily atop restart
    Loaded: loaded (/usr/lib/systemd/system/atop-rotate.timer; enabled; vendor preset: enabled)
    Active: active (waiting)
  3. Run the following command to stop atop after troubleshooting to release the system and disk resources occupied by atop:
    systemctl disable atop atopacct atop-rotate.timer
    systemctl stop atop atopacct atop-rotate.timer
Configuring atop for Ubuntu 16 and Debian 8
    apt-get install -y atop
    vi /etc/default/atop
    • The default retention period of atop logs is 28 days and cannot be modified.
    LOGINTERVAL=15
    systemctl start atop
  2. Run the following command to check the status of atop. active (running) indicates that atop is running properly.
    Loaded: loaded (/etc/init.d/atop; bad; vendor preset: disabled)
    systemctl stop atop
Configuring atop for Ubuntu 18 and Debian 9
    vi /usr/share/atop/atop.daily
    • You can change the value of -mtime to, for example, 3. The default retention period of atop logs is 28 days.
    LOGINTERVAL=15
    ( (sleep 3; find $LOGPATH -name 'atop_*' -mtime +3 -exec rm {} \;)& )
  1. Restart the atop service (started by default) to apply the configuration:
    systemctl restart atop atopacct
    Loaded: loaded (/etc/init.d/atop; enable; vendor preset: enabled)
Configuring atop for Ubuntu 20 and Debian 10
    LOGINTERVAL=15
    LOGGENERATIONS=3
Configuring atop for Ubuntu 22 and Ubuntu 24
    LOGINTERVAL=15
    LOGGENERATIONS=3
  3. Restart the atop service (started by default) to apply the configuration:
    systemctl restart atop atopacct atop-rotate.timer
  4. Check whether atop is started. If atop atopacct is active (running), or atop-rotate.timer is active (waiting), the service is running properly.
Configuring atop for Debian 11 and Debian 12
    LOGINTERVAL=15
    LOGGENERATIONS=3
Configuring atop for SUSE 12 and SUSE 15
  1. Run the following command to download the atop source package:
    wget https://www.atoptool.nl/download/atop-2.6.0-1.src.rpm
  2. Run the following command to install the atop source package:
    rpm -ivh atop-2.6.0-1.src.rpm
  3. Run the following command to install atop dependencies.
    zypper -n install rpm-build ncurses-devel zlib-devel
  4. Run the following commands to compile atop:
    cd /usr/src/packages/SPECS
    rpmbuild -bb atop-2.6.0.spec
  5. Run the following commands to install atop:
    cd /usr/src/packages/RPMS/x86_64
    rpm -ivh atop-2.6.0-1.x86_64.rpm
  6. Run the following command to modify the configuration file of atop:
    LOGINTERVAL=15
    LOGGENERATIONS=3
Configuring atop for Huawei Cloud EulerOS (HCE) 2.0
    yum install -y atop
  2. Set the sampling period.
    The sampling period has been preset in the HCE and does not need to be adjusted. By default, the sampling period is 10 seconds, and logs are stored for three days.
  4. Check whether atop is started. If atop atopacct is active (running), or atop-rotate.timer is active (waiting), the services are running properly.
  5. Run the following commands to stop atop after troubleshooting to release the system and disk resources occupied by atop:
Installing atop by Compiling the Source Code (for CentOS Stream 8/9, openEuler, or EulerOS)
  1. Download the atop source package.
    wget https://www.atoptool.nl/download/atop-2.6.0.tar.gz
  1. Decompress the atop source package.
    tar -zxvf atop-2.6.0.tar.gz
  2. Query the systemctl version.
    systemctl --version
    If the version is 220 or later, go to the next step.
    Otherwise, delete parameter --now from the Makefile of atop.
    vi atop-2.6.0/Makefile
    Delete parameter --now following the systemctl command.
                    then   /bin/systemctl disable  atop     2> /dev/null; \
                            /bin/systemctl disable  atopacct 2> /dev/null; \
                            /bin/systemctl daemon-reload;                   \
                            /bin/systemctl enable   atopacct;          \
                            /bin/systemctl enable   atop;              \
                            /bin/systemctl enable   atop-rotate.timer; \
  3. Install atop dependencies.
    • Installing command for SUSE 12 or SUSE 15
      zypper -n install make gcc zlib-devel ncurses-devel
    • Installing command for EulerOS or Fedora
      yum install make gcc zlib-devel ncurses-devel -y
    • Installing command for Debian 9, Debian 10, or Ubuntu
      apt install make gcc zlib1g-dev libncurses5-dev libncursesw5-dev -y
  4. Compile and install atop.
    cd atop-2.6.0
    make systemdinstall
  5. Run the following command to modify the configuration file of atop:
    Add the following parameters, save the modification, and exit:
    LOGOPTS=""
    LOGINTERVAL=15
    LOGGENERATIONS=3
    LOGPATH=/var/log/atop
Analyzing atop Logs
After startup, atop stores collection records in /var/log/atop.
Run the following command to check the log file:
atop -r /var/log/atop/atop_2024XXXX
  • Common atop commands
    After opening the log file, you can use the following commands to sort data:
    • c: used to sort processes by CPU usage in descending order.
    • m: used to sort processes by memory usage in descending order.
    • d: used to sort processes by disk usage in descending order.
    • a: used to sort processes by the overall resource usage in descending order.
    • n: used to sort processes by network usage in descending order.
    • t: used to go to the next monitoring collection point.
    • T: used to go to the previous monitoring collection point.
    • b: used to specify a time point in the format of YYYYMMDDhhmm.
  • System resource monitoring fields
    The following figure shows some monitoring fields and values. The values vary according to the sampling period and atop version. The figure is for reference only.
    Figure 1 System resource monitoring fields
    Description of major fields is as follows:
    • ATOP row: Specifies the host name and information sampling date and time.
    • PRC row: Specifies the running status of a process.
    • #sys and user: Specifies how long the CPU is occupied when the system is running in kernel mode and user mode.
    • #proc: Specifies the total number of processes.
    • #zombie: Specifies the number of zombie processes.
    • #exit: Specifies the number of processes that exited during the sampling period.
    • CPU row: Specifies the overall CPU usage (multi-core CPU as a whole CPU). The sum of the values in the CPU row is N x 100%. N indicates the number of CPUs.
    • #sys and user: Specifies the percentage of how long the CPU is occupied when the system is running in kernel mode and user mode.
    • #irq: Specifies the percentage of time when CPU is servicing interrupts.
    • #idle: Specifies the percentage of time when CPU is idle.
    • #wait: Specifies the percentage of time when CPU is idle due to I/O wait.
    • CPL row: Specifies CPU load.
    • #avg1, avg5 and avg15: Specifies the average number of running processes in the past 1, 5, and 15 minutes, respectively.
    • #csw: Specifies the number of context exchanges.
    • #intr: Specifies the number of interruptions.
    • MEM row: Specifies the memory usage.
    • #tot: Specifies the physical memory size.
    • #free: Specifies the size of available physical memory.
    • #cache: Specifies the memory size used for page cache.
    • #buff: Specifies the memory size used for file cache.
    • #slab: Specifies the memory size occupied by the system kernel.
    • SWP row: Specifies the usage of swap space.
    • #tot: Specifies the total swap space.
    • #free: Specifies the size of available swap space.
    • DSK row: Specifies the disk usage. Each disk device corresponds to a column. If there is an sdb device, a DSK row should be added.
    • #sda: Specifies the disk device identifier.
    • #busy: Specifies the percentage of time when the disk is busy.
    • #read and write: Specifies the number of read and write requests.
    • NET row: Displays the network status, covering the transport layer (TCP and UDP), IP layer, and active network ports.
    • #xxxxxi: Specifies the number of packets received by each layer or active network port.
    • #xxxxxo: Specifies the number of packets sent by each layer or active network port.
(Optional) Loading the netatop Kernel Module
The netatop kernel module can monitor the statistics of TCP and UDP data packets sent and received by each process or thread. In atop, netatop is not installed by default. If you need to monitor the network usage, install it by referring to the description below.
Huawei Cloud EulerOS 2.0 is used as an example to describe how to load the netatop kernel module for atop.
To load the netatop kernel module on other Linux operating systems, see Module netatop in the official atop help documentation.
  1. Run the following command to install the kernel development package and the software environment required for compilation on the kernel:
    sudo yum install -y kernel-devel dkms elfutils-libelf-devel
  2. Run the following command to download the source code of the latest netatop to the specified directory:
    cd /usr/src/ && sudo wget https://www.atoptool.nl/download/netatop-3.2.2.tar.gz --no-check-certificate
  3. Run the following command to decompress the source code and go to the source code directory:
    sudo tar -zxvf netatop-3.2.2.tar.gz && cd netatop-3.2.2
  4. Run the following command to build and install the module and daemon based on the source code:
    sudo make && sudo make install
  5. Run the following command to start netatop:
    systemctl start netatop
Precautions for Configuring kdump
The method for configuring kdump described in this section applies to KVM Linux ECSs running EulerOS or CentOS 7.x. For details, see Documentation for kdump.
Introduction to kdump
Kdump is a tool used to dump runtime memory when the system crashes. Once the system crashes, the kernel can no longer function properly. At this point, Kdump boots another kernel to capture and save a memory dump. This kernel collects all runtime states and data and stores them in a dump core file for troubleshooting and debugging.
Configuring kdump
  1. Run the following command to check whether kexec-tools is installed:
    rpm -q kexec-tools
    If it is not installed, run the following command to install it:
    yum install -y kexec-tools
  2. Run the following command to enable kdump to run at system startup:
    systemctl enable kdump
  3. Configure the crashkernel parameter to reserve the memory for the capture kernel.
    Run the following command to check whether the parameter has been configured:
    grep crashkernel /proc/cmdline
    If the command output is displayed, this parameter has been configured. If no command output is displayed, you need to configure crashkernel.
    Edit the /etc/default/grub file to configure crashkernel as follows:
    GRUB_TIMEOUT=5
    GRUB_DEFAULT=saved
    GRUB_DISABLE_SUBMENU=true
    GRUB_TERMINAL_OUTPUT="console"
    GRUB_CMDLINE_LINUX="crashkernel=auto rd.lvm.lv=rhel00/root rd.lvm.lv=rhel00/swap
    rhgb quiet"
    GRUB_DISABLE_RECOVERY="true"
    Locate parameter GRUB_CMDLINE_LINUX and add crashkernel=auto after it.
  4. Run the following command for the configuration to take effect:
    grub2-mkconfig -o /boot/grub2/grub.cfg
  5. Open the /etc/kdump.conf file, locate parameter path, and add /var/crash after it.
    path  /var/crash
    By default, the file is saved in the /var/crash directory.
    You can save the file to another directory, for example, /home/kdump. Then add /home/kdump after parameter path:
    path  /home/kdump
    There must be enough space in the specified path for storing the vmcore file. It is recommended that the available space be greater than or equal to the RAM size. You can also store the vmcore file on a shared device such as SAN or NFS.
  6. Set the vmcore dump level.
    Add the following content to file /etc/kdump.conf. If the content already exists, skip this step.
    core_collector makedumpfile -d 31 -c
    In the preceding command:
    -c indicates compressing the vmcore file.
    -d indicates leaving out irrelevant data. Generally, the value following -d is 31, which is calculated based on the following values. You can adjust the value if needed.
    zero pages   = 1
    cache pages   = 2
    cache private = 4
    user  pages   = 8
    free  pages   = 16
  7. Run the following command to restart the system for the configurations to take effect:
    reboot
Checking Whether kdump Configurations Have Taken Effect
  1. Run the following command and check whether crashkernel=auto is displayed:
    cat /proc/cmdline |grep crashkernel
    BOOT_IMAGE=/boot/vmlinuz-3.10.0-514.44.5.10.h142.x86_64 root=UUID=6407d6ac-c761-43cc-a9dd-1383de3fc995 ro crash_kexec_post_notifiers softlockup_panic=1 panic=3 reserve_kbox_mem=16M nmi_watchdog=1 rd.shell=0 fsck.mode=auto fsck.repair=yes net.ifnames=0 spectre_v2=off nopti noibrs noibpb crashkernel=auto LANG=en_US.UTF-8
  2. Run the following command and check whether the information in the output is correct:
    grep core_collector /etc/kdump.conf |grep -v ^"#"
    core_collector makedumpfile -l --message-level 1 -d 31
  3. Run the following command and check whether the information in the output is correct:
    grep path /etc/kdump.conf |grep -v ^"#"
    path /var/crash
  4. Run the following command and check whether the value of Active in the output is active (exited):
    systemctl status kdump
    ● kdump.service - Crash recovery kernel arming
    Loaded: loaded (/usr/lib/systemd/system/kdump.service; enabled; vendor preset: enabled)
    Active: active (exited) since Tue 2019-04-09 19:30:24 CST; 8min ago
    Process: 495 ExecStart=/usr/bin/kdumpctl start (code=exited, status=0/SUCCESS)
    Main PID: 495 (code=exited, status=0/SUCCESS)
    CGroup: /system.slice/system-hostos.slice/kdump.service
  5. Run the following test command:
    echo c > /proc/sysrq-trigger
    This command will trigger kdump. When triggered, kdump will boot another kernel and store the generated vmcore file to the location specified by path.
  6. Run the following command to check whether the vmcore file has been generated in the specified path, for example, /var/crash/:
    ll /var/crash/
