Help Center/ Elastic Cloud Server/ Troubleshooting/ Configuring the Network/ Why Does the NIC Names Change After I Start a Linux ECS?
Updated on 2025-07-30 GMT+08:00
After an ECS running CentOS 6 created using a private image starts, the first NIC is named as eth1, rather than eth0.
This solution provided in this section involves restarting the ECS. Restarting the ECS will interrupt services running on it. Exercise caution when performing this operation.
Possible Causes
The /etc/udev/rules.d/70-persistent-net.rules file still records the mappings between NICs and MAC addresses in the private image. You need to disable the rules.
Solution
  1. The correct way to disable udev is to overwrite it with an empty file. Any rules in /etc/udev/rules.d take precedence over the rules in /lib/udev/rules.d. Run the following command to create an empty file:
    touch /etc/udev/rules.d/75-persistent-net-generator.rules
  2. Restart the ECS.
    reboot
