How Do I Change the Key Pair for a Linux ECS?
Symptom
You changed the key pair for logging in to a Linux ECS, but you could not use the new key pair to log in to the ECS.
Solution
- Use the password or old key to log in to the ECS and run the following commands to create a key pair:
[root@host -]$ ssh-keygen <==Create a key pair. Generating public/private rsa key pair. Enter file in which to save the key (/root/.ssh/id_rsa): <== Press Enter. Created directory ´/root/.ssh´. Enter passphrase (empty for no passphrase): <== Enter the key passphrase or press Enter to leave it blank. Enter same passphrase again: <== Enter the key passphrase again. Your identification has been saved in /root/.ssh/id_rsa. <== Private key Your public key has been saved in /root/.ssh/id_rsa.pub. <== Public key The key fingerprint is: 0f:d3:e7:1a:1c:bd:5c:03:f1:19:f1:22:df:9b:cc:08 root@host
- Set a key passphrase when a private key is used. This prevents the private key from being stolen.
A hidden directory .ssh is generated in the home directory of user root user. The directory contains two key files: id_rsa (private key) and id_rsa.pub (public key).
- Run the following commands on the Linux ECS to install the public key:
[root@host ~]$ cd .ssh [root@host .ssh]$ cat id_rsa.pub >> authorized_keys
- To ensure successful connection, run the following commands to configure file permissions:
[root@host .ssh]$ chmod 600 authorized_keys [root@host .ssh]$ chmod 700 ~/.ssh
- (Optional) Edit the /etc/ssh/sshd_config file as follows to enable SSH key pair login. (Skip this step for Linux ECSs created using a public image because key pair login has been enabled for them by default.)
RSAAuthentication yes PubkeyAuthentication yes
- Check the following configuration item to ensure that user root can log in to the ECS using SSH:
PermitRootLogin yes
- After the preceding configuration is complete and the login using a key is successful, run the following command to disable password login:
- Restart SSH.
Follow-up Operations
- Download the private key to your local computer and convert it into a format that can be used by PuTTY.
Use WinSCP or SFTP to download the private key file id_rsa. Keep the file secure.
- Open PuTTY Key Generator and click Load an existing private key file in Actions to load the downloaded private key file.
If you have set a key passphrase, you need to enter it.
- After the private key file is loaded successfully, PuTTY Key Generator displays the information about the key.
- In the Key comment box, enter the description of the private key and click Save private key to save the private key file in a format that can be used by PuTTY.
- Use PuTTY to log in to the ECS. In the navigation pane of PuTTY, choose Connection > SSH > Auth, and in the Private key file for authentication area, browse to and select your private key file, enter the key passphrase, and click Open to log in to the ECS.
